Hal Golightly
- Jan 1, 2007
Up for sale is a SureFires Saint Model HS1-A-BK. Surefire engineers created a virtually indestructible headlamp that overwhelms the darkness with a wide yet powerful beam optimized to match your field of vision. It's all controlled by a variable light output dial designed for one-handed use, even with fingers that are cold or gloved, enabling you to dial it up or down from 0 to 100 lumens with a simple turn. Saint is made from hard anodized aerospace-grade aluminum that's built to last and its custom-made headband, accented with moisture-wicking Breathe-O-Prene" pads, comfort and dryness.
The coated refractive optic, created by SureFire engineers, gathers and shapes the light produced by a high-quality LED to form a perfectly balanced beam designed to fit your field of vision. There are no hot spots, rings, or defects; just a smooth white beam that corresponds nicely with your peripheral vision, even for close-up work. The variable light output dial allows for continuous output adjustments from 0 to 100 lumens so you get the light output you need for the task at hand. This also enables you to conserve power so you can go for days on a single set of batteries. And this one-of-a-kind variable light output dial was designed to be operated with just one hand even if that hand is gloved or numb from plunging temperatures. The light assembly also angles up or down 90 degrees, with one hand, to light your way no matter what the terrain or situation. And it was built with an SOS beacon that'll run for days on end.
The Saint will operate with one, two, or three 123A lithium batteries or two AA alkaline batteries. It will run longer and more efficiently with lithium batteries, especially in colder temperatures, but it was designed to perform well with AA alkaline too. This Dual-Fuel capability gives you the flexibility you need out in the field and it's unique only to Saint.
The Saint headlamp is designed to be tougher than the rest and also. It uses a custom micro-fiber material that's thin, tough, and soft. Small, low profile metal buckles and smooth stitching ensure a comfortable fit. The unique cable management system serves multiple functions. The three-snap design allows you to easily secure excess cable leading into the housing. This keeps it out of the way and provides cable relief which extends the life of your headlamp. The specification of the light are as follows:
Switching: Continuously variable light output dial
Output: 0 to 100 lumens with SOS beacon
Runtime: 6 hrs at 100 lumens / 48 hrs at 10 lumens / 144 hrs at 1 lumen
Beam Distance: 42 m at 100 lumens / 13 m at 10 lumens / 4 m at 1 lumen
Waterproof: One meter for 30 minutes
Weight: 8.7 ounces
Batteries: Up to three SureFire 123A lithium batteries or two AA alkaline batteries
Material: Aerospace-grade aluminum and Xenon polymer
Finish: Mil-Spec Type III hard-anodized aluminum
Color: Black
Model Number: HS1-A-BK UPC Number: 08487131161
The light has never been used or carried, I purchased it put it in a drawer and
that is wear it has sat till today. was $110.00 now $100.00 shipped. SPF
The First "I'll take it" with a follow-up e-mail (halgolightly@yahoo.com) or PM wil
get the light. The price of the items will include the Paypal fees. I will ship the
items USPS priority mail insured. For sale in the CONUS and Hawaii. Thanks for
looking.
Weight: 8.7 ounces
Color: Black
looking.
