- Sep 2, 2008
Wow, that iTP C7T is even more affordable. I've got a lot of reading to do
Thanks guys.
While not as small as that Surefire, I'd probably go with an ITP C7T. Using a single AA battery, it can put out 190 lumens with the CREE Q5 diode, while also being fully adjustable to as low as 6 lumens. For the price, it seems like a real winner.
Wow what a neat looking little light. Does it really put out 190 lumens? Any idea of the runtime on that thing? I'd imagine it would have to be less than an hour given 190 lumens from a single double A. Seems a little long though. The length is about the same as a fullsized folding knife. Not sure if I'd want to hang it on a keychain but it would make a great pack light.
I really want that Polarion PH40 "Helios" HID Searchlight. That monster barfs out 4150 LUMENS for about 70 minutes! But $2,200.00 is a lot to spend on a flashlight LOL.
I have no problem paying top dollar for quality equipment and even have a decent collection of Surefires but the T1A seems like a bit much...
I've got a Fenix LD01 on my keychain. 80 lumens on high 10 lumens on low. And for the price of the T1A, if I break my LD01, I can buy 3 more...
The Nitecore EZAA is another option running on a single AA, putting out 130 lumens and also around $50.
He said that it's probably one of the few flashlight that has recoil when you turn it on.![]()
+1 :thumbup: two excellent recommendations
I showed the specs to my son. (He's a physicist) He said that it's probably one of the few flashlight that has recoil when you turn it on.
For the uninitiated, he has the same sense of humor as his old man. Droll.![]()
4150 lumens is absurd!
The longer I have the M6 from Surefire the weaker it seems, 500 lumens is a lot, but I need a few more like 3000 or so.
I used to EDC the Nitecore EX10... but it had two properties that put me off.+1 :thumbup: two excellent recommendations, the LD01 is tiny and bright as hell I love mine, but I like the Nitecore EZAA even more, simple to use, no switches to break, good balance of brightness and battery life and the quality on the nitecore lights is outstanding. Personally I EDC a Nitecore D10 R2, easy to use with 100 levels of brightness and a memory that saves your setting when you turn it off. with a duracell rechargeable it can get around 1.5 hours on high and 60+ on low.
Firstly, it's water-resistant... but not waterproof by any measure. I tested it by dipping it into water, and got water inside... even after after I disassembled it, lubed it, and carefully reassembled it. This never happened with my Fenix lights.
The reason has nothing to do with build quality, but rather with the design. The glass lens on the EX10 is floating, and does not rest against a lip with an o-ring the way most other lights do. This is something I feel they should've addressed with the R2 edition... but they didn't.
The EX10 seemed to be okay in this test...
I haven't noticed any problems with submerging my Nitecores in water either. Maybe yours is missing an o-ring?
All the o-rings are there, and I've actually added a couple. My EX10 can be submerged, but the switch cannot be operated underwater... and even though it does not interfere with the function of the light during the intervals I used in my testing, condensation appears on the inside surface of the lens.
That being said, I don't go diving with it, and it's been fine in pouring rain, so it's sufficient for my purposes... which is why I kept the light.
