Here are some pictures that I hope will give an idea of how Charlie converted our surface grinder to a belt operation.
The contact wheel came from Contact Rubber Corp., Bristol WI
It is an 8" wheel, C134 Quick-change tire 39706 90 Duro
The steel tubing is 2" square with 1/4" wall thickness, and the inside tubing is 1.5" square
The inside tube rests on two coil compression springs inside the larger tube that provide the belt tension.
The top tracking wheel was purchased at the Blade Show
The collar that fits around the housing for the shaft of the grinder is a piece of 4" pipe 1/4" thick. It just is a slide fit on the grinder housing and has been split. Two pieces of angle iron were bolted to either side of the split so that it could be tightened to the housing with screws.
Overall picture
collar showing tube welded to it and method of tightening it to grinder housing
This picture shows some detail of the tracking wheel and the tube construction as well as a highly technical method of reducing tension on the shaft so that belts can be changed.
More detail of the tracking wheel.
I hope this helps. Be careful if you build this conversion. It worked for us, but we don't know what other types of grinders are out there and each one needs to be designed individually.
