- Aug 13, 2002
Eric, could you point me in the direction of the thread about your KMG gas spring setup? Might as well give that a try too while I am at it.
Thanks
Thanks
???The big benefit is less heat build up in deeper cuts. With a stone, anything more than .0005" required flood coolant to keep from getting the blade steel too hot and warping. With a belt, I am quite comfortable taking a .005" cut with a 50 grit belt. Another benefit is the ability to change grits quickly to get finer finishes. With vitrified stone wheels, every time you replace a stone you must dress it for concentricity. That can be time consuming. Belts just swap and go.
BTW-Everybody will develop their own system for working the belts but I'll just mention that I pretty much only use a 50 grit Blaze to rough and a Trizact A65 to finish.
Bob
