What is the best way to make flat parts for folders. I would expect that a surface grinder would be the best. Is there any other options (cheaper, lighter easier to find)
thanks
thanks Barks, would a surface grinder from grizzly or harbor freight work?
thanks
Heatride,what do you mean "a granite rock and a elbow"? also, ive now use a 4by36 belt sander its all i can afford. i was going to buy the plans and make the 2 by 72 "no weld grinder" but after all the posts about grinders i am thoroughly confused. with the nwg i can build the base setup and expand as i am financialy able. do you fellows think that is a good plan?![]()
I did read somewhere that Tony Bose does use a 4 x 36 belt sander to flatten parts.
thanks
I use a surface grinder from Harbor Freight. It cost me $999.00 8 years ago. I had to do some minor tuning and truing but it grinds things within .0001. It was well worth the money, and has saved me many many hours in flattening material. I purchased the 6x12 magnetic chuck from HF also. Once you mount the chuck be sure to true it up by grinding it with your new grinder. Be sure to throw away the crappy wheels that come with it and purchase new ones from a US maker. If you have never used a surface grinder you should probably find somone with experiance that can show you proper use and dressing of the wheel. You will also want them to show you the proper way to grind something.
