I use compressed air to clean off my mag chuck. Works fastpinching a blood blister - I've done that with my chuck. With my aluminum chuck I wound up filling the slots with epoxy so the top if fully smooth. This allows removing the grinding dust easier. That grinding dust really holds to the magnetic chuck.
Thanks, Ken, I appreciate it. I already made some modifications to it today, but they were part of the plan. I drilled and counter sunk new mounting holes in the rail today to offset the chuck to the right. This gives a lot more clearance for cleaning and putting long blades on the chuck as you can see in the picture. I initially used the bolt holes that were already in the rail because I wanted to measure the offset after the end stops were in place. I also drilled a mounting hole for the handle at the end of the chuck.Hubert, I think your SGA is about the most professional setup I've seen built. Good job! You're right, you gonna LOVE the SGA and wonder how you ever got along without it.
The thread is 3/8"-24. I went in 1 thou increments on the hardened steel I ground, but I had a 120 grit belt on there. I did not measure to see how well the dial indicator reading matched the actual material removal yet, but I plan to do that at some point. I'll post results here when I get around to it.Looks like you've got a 1/2"X20 thread to adjust? That gives .050" per round? AND a nice setup for the dial indicator. I'll be very interested to know when you move the dial indicator, say .010", how much material that will take off. I took my dial indicator off, decided I didn't really need it there and used it elsewhere. Most of my adjustments while grinding are in the .005" range, or even less. Even .005" is a BIG cut for a real surface grinder. Back 50 yrs ago when I ran a surface grinder in a shop .001" was considered a big cut, and sometimes in the tenths of a thou range. Of course the surface grinder was using stone wheels rather than a belt.
Ken, I did a test today on a piece of mild steel to see how well the dial indicator reading matched the actual material removal. I used a 120 grit ceramic belt and did two increments of 2.5 thou for a total of 5 thou between measurements. I repeated this four times and took the piece from 0.12" down to 0.1". I only used calipers for this test, but the readings were all spot on.I'll be very interested to know when you move the dial indicator, say .010", how much material that will take off.
3D printers are really nice for prototyping. I suspect the printed handle will be on there for a while, I want to make some knives before spending more time on the SGA. I don't use Fusion 360, I never really learned CAD. We still did all drawings by hand when I went through school. I tend to use a program called OpenSCAD where you define shapes and add/subtract them from each other to arrive at your final model. All this is done via a text file, which I edit using Emacs. For the handle, I cheated a bit and drew the cross section in Inkscape and then simply extruded it in OpenSCAD.Good deal on the printed handle. Did you draw that up in Fusion360? I just recently got a 3D printer (Ender 6) and use FreeCAD for drawing projects. I had no idea I'd use the 3D printer as much as I have over the couple of months I've had the printer. I suspect that printed handle will last just fine, and be a LOT less expensive than the size of Micarta would be.
That's a good test - I've never really tested my SGA like that with 120 grit, only with 36 or 50 grit and that's pretty large grit for accurate testing. For each .005" moved in, I'd get maybe .003" or so removed. I do have a fairly soft wheel which would make a difference, and taking light cuts rather than "hogging" would also help the accuracy on removing material.
