Survival Straw - good? bad?
RokJok
Has anyone tested or had field experience with the Survival Straw?? If it works as advertised, for about $35 it would make a handy addition for hiking, bugout bags, or emergency situations.
http://www.safetycentral.com/survivalstraw.html
Thanks in advance for all info,
Greg
p.s. I did find this info in a thread from y2k timeframe.
<font face="Verdana, Arial" size="2">Originally posted by Doug Varney:
The survival straw works on the redox (Reduction Oxidation)principle. This technique is very effiecient in destroying many pathogens. As with all these sterilizing methods they require a rentention time for them to be effective. Just as the water must be left to sit in the chlorox or iodine for a period of time before drinking , the water must remain incontact with the ionizing metals with in the straw in order to be effective. I have been unable to obtain the recommended rentention time for this device, however simply drawing water straight throught the straw seems like too little time to do a proper job. </font>
Wow, very interesting. I have never seen one before now but if it works it would be a great alternative to filters.
I guess it could work. I'm a little suspicious of gadgets that ascribe near miraculous qualities to ionization.
Seems like it would also either have to be cleaned pretty often if you are filtering water from a stream or it couldn't do all that good of a job of getting rid of grit.
[This message has been edited by Mr E Blackadder (edited 06-27-2001).]
ROKJOK;
Before starting out on a hike, fill up your canteens with good fresh water.
In you b.o.b. have something in which you can boil your water.
This is more of a guarantee for having good drinkable water then a "magic straw" no matter what they put in it....be safe.
Ron,
Bremerton, Washington
They clog up really really fast. I didnt like it.They have been around at least since the early 80s. Im not sure how good they are as far as purifying,filtering.
Dude >>> check yer six >>>
The one I have is supposed to work by micropore filtration. Yes it clogs up fast, and you are supposed to get the silt out of the water before you pull it through the straw or it won't work for long. The one I have can not be cleaned. Its rated to filter a certain number of gallons and they you have to throw it out. The company also told me that it had an indefinate shelf life, but once I used it, I should toss it within a month no matter how much water I've filtered due to bacterial growth in or on the filter itself.
So I keep one in my jump kit just in case, but otherwise plan to use other options (boiling, iodine) as first lines of defense.
I would be very careful with this item. "If it sounds too good to be true, it probably is."
It is my understanding that water is treated 3 ways: filtration, heat, or chemicals. The text says there is no filter, and the water isn't heated, so that leaves chemical treatment. For this to be effective, there must be standing time, usually 30 minutes or so.
The text makes a lot of claims that I would call suspicious; the name of the maker is not given; and there's no info on the 'special alloys' that 'eliminate' the baddies.
It says it doesn't filter the impurities, it 'eliminates' them. What does that mean? Where do they go? They have to go somewhere. Sounds to me like they stay in the water and you swallow them.
Mercury and arsenic are elements. They can't be 'destroyed,' that is, changed into something else. If you could do that, you could change lead into gold, right?
It is my understanding that the only way to remove certain impurities from water is to put the water through a distillation process.
The text says that the straw 'meets EPA and FDA standards.' The EPA regulates public water distribution systems, that is, municipal water supplies. It does not regulate privately owned wells, for example. My opinion is that the statement is actually saying, it meets EPA standards, because there ARE no standards that apply to this item. I stress that this is my opinion only, and I could be wrong.
I didn't have much luck attempting to navigate the EPA website so I didn't even look at the FDA website.
Here's what Doug Ritter has to say about survival straws:
http://www.equipped.com/watrfood.htm
(look near the end of the page)
Here's another reference to the straw:
http://www.providenceco-op.com/waterfaq/waterfaq.htm
(last paragraph at the bottom of the page)
Backpackers, and especially the ultralight backpackers, are very gear oriented and seek out the light weight and compact stuff. Yet there's no info about this item at any of the backpacker sites (at least in the search I made).
The only reference to this item is at emergency preparedness type sites, with the exception of Cabela's which is more of a hunting and fishing site. IF this item worked, you can be sure that all the backpacker stores would sell it, and ultralight backpackers all over would devote lots of text to praising it.
Here's a site with reviews of various water filters. These manufacturers aren't afraid to put their name, address and phone number on their products:
http://www.outdoorreview.com/reviews/Water_Filters/
Home page:
There are filters at the above site that are about the same size and the in the same price range as the survival straw. One is an inline filter, and the other is a water bottle with a built in filter. Look for Aquamira and Safe Water Anywhere at outdoor review.
There was a survival straw website at one time, around 1998, but it is defunct:
www.survivalstraw.com
I carry a PUR Hiker in by big kit along with paper coffee filters to use as a pre-filter. This is backed up by Potable Aqua tablets, which I also have in my small kit. I also carry a bottle of Polar Pure iodine crystals in my truck.
I'm more of a keyboard commando (love that term) than anything else, but I did a lot of research on the topic of water treatment before I bought my Pur Hiker.
I will step off my soapbox now.
I have tried a water bottle with a built in filter that works well. The water tastes good. It is practical and easy to use. Deal Spot removed. Please pay attention to our rules at BFC. Link removed since it did not pertain to the actual question of the original post.
I heard they suck......Or you suck it....Someth'n like that......
