Ok, ok - I give. For the sake of argument, here and now only, lets take my own personal design:
1) Western Washington State, rural, on a 20 ft hillside in post ice-age river terraces. 30 acres total property. Sediments are deep, >100 ft, and the water table is ~15 ft below the surface. The aquifer produces ready-to-drink water from a well and is unlikely to drop more than 50 ft in 10 years of drought. Average ground temperature is 45 deg F regardless of season. Soil is suitable for pasture or orchards as is.
2) No outside utilities. This leaves solar-electric (unlikely in the 1st year), wind, and hydro from a river in the back of the property. Frankly, I'm not an electrical engineer, so could use some help in that area.
3) Forces. I am using severe earthquake forces because as I type, the (east-moving) floor of the Pacific is locked up against the bottom of the (west-moving) North American continent. Historically, this subduction zone lets loose every 300 years - the last time was 302 years ago, when the coast dropped ~3 ft in a matter of minutes. Hence the 0.5 g, far worse than earthquake codes require. I want to come through in one piece.
Meteorite imapct force, I think, is pretty binary. With minor variations in survivability around the edges, you either get splatted or you don't. It is too expensive to make another NORAD, so I am just figuring for my "pet" earthquake.
The electrical system will be hardened against EMP from lightning, which is in the GHz range.
4) Occupants: 2 adults + pets with temporary (months) capabilities for 10 more.
5) I am modeling a totally dark show for 12 months. This probably means freezing weather the whole time. After that, the sun should be out enough to raise some crops in a greenhouse at mid 50s temps, say 2000 square feet. Again, botany is not my area and I could use help here. I am assuming a "wierd climate" period of 10 years, which may as well be eternity for design purposes. Basically this means sunlight, but unknown and variable temps, precipitation.
Before the event, it is my house. It should look like a house too, albeit a sheltered one. Picture the south wall exposed and a patio or deck. Concrete can be colored cheaply too, by the way.
6) I'm not sure what you mean by "survival and exit phases and durations".
7) The plan is to stay put for a while, then rebuild life with everyone else. I suppose there might be a period of lawlessness. Occupants will likely have 2000 cubic feet worth of personal storage inside each, more in outbuildings.
8) Budget. I'm figuring $100k for a liveable home, 4500 square feet. (I know, not 3000 sf like I said, but this one is mine.) Liveable to me means warehouse-type floors and dyed concrete counters, not fancy. Fancy can come later, but there will be pictures on the walls and lots of nice plants from the start. This also means I do most of the formwork, etc. If I get hurt and can't do such work, the price may double.
9) Maintenance. Welding, concrete, wood, etc. Basically your typical farm shop. This will be in the above ground garage, which will be the house while the real one is being constructed.
Speak of the devil. I just got an email from a NASA list describing new research about the K-T event. I know everyone wants a more precise definition - this is as specific as I can get:
http://ali.opi.arizona.edu/cgi-bin/...s?ArticleID=5767&wosid=G1Qx2jcSGUlM5fXNis6GWw
EARTH SUFFERED PULSES OF MISERY IN GLOBAL WILDFIRES 65 MILLION YEARS AGO
As an example of how poorly constrained the problem is, the idea of global fires is only a year or so old. Before that the thinking was that everything would freeze. I'm not just being goofy by not constraining the criteria - the criteria really aren't known. If this new research proves well-founded, air filtering/cooling becomes very important.
Scott
PS - maybe a better way to think of my criteria is, "How far can one go with an earth sheltered home? What are the limits of survivability?" It is more about finding limits than setting them.
