ck out http://www.yahoo.com/ and go to the video link regarding three boys who survived a fall through the pond. The link will likely only be active today.
Basically one of the boys watched this Bear Gillis (sp) ladie-oh and so took off all his clothes as demonstrated by Bear and ran for help. He survived so now we have more of this "advice" getting out to the masses.
If you are wearing wool like you should, roll in the snow and use it as a blotter to reduce the soaking...and then go make a fire and dry out unless help is very close. This method should also work with fleece and synthetics. Good clothes have some insulating properties when wet.
If you are wearing all cotton and are a few hundred yards from help the above advice might be ok but will certainly shock the neighbors.
In these conditions blotting the soaking clothes in snow and running for help might work as well and will improve your reception at the door especially if you are as fat as I am!
The problem with TV as media is that marginal advice becomes generalized and this could have deadly effects. Try shedding your clothes and heading for help in the NWT in January and that's the end of you!
