Maybe he knew something about that mushroom that he wasn't telling.Cliff Stamp said:One of the more idiotic was eating a mushroom that he hoped would not be poison, all done with a smile on his face.
-Cliff
-Cliff
x39 said:Maybe he knew something about that mushroom that he wasn't telling.
LSkylizard said:However, I did mention the point to you simply as one possibility to your question on how to avoid getting blood/gore on your hands.
I would say that one of the worst things he did was drink directly from a puddle ringed with what he described as rat dung.do/feces....that is frightening!
Cliff Stamp said:How do you deal with cleaning them assuming your hands/knife becomes contaminated...
Cliff Stamp said:Various techniques to catch game will prooduce a lot of blood, so just handling it can cause contamination and plus cleaning it induces more...
Cliff Stamp said:...Yes, and the method he uses is not how to do that and could readily lead to direct contamination, accidental contamination later on and cross contamination from many sources...
Cliff Stamp said:...He does things much worse than that, things which could kill you instantly and he does it in every episode...
LSkylizard said:I still say all you can do is to do the best you can and spare the H2O you can spare in a given situation.
I am curious as you seem to disagree with what he did and what has been posted by some.
The way healthcare re-imbursements are being cut today, I may have to do without soapCliff Stamp said:Consider heading into an operating room and you can't wash your hands nor any of the instruments (or you can but no soap and you don't know if the water is actually clean and you don't have a lot of it)...
LSkylizard said:All bets are off if you use prilosec or or some other acid blocking medications.This caught my attention, since I suffer from GERD and take prilosec. So to make sure I understand what you are saying, since I'm blocking some acid, I'm reducing the ability to kill pathogens that get into my stomach, increasing my chances of food poisoning?
Cliff, I was being facetious. I was alluding to the fact that some fungi have psychotropic properties.Cliff Stamp said:Consider what it implies about the possible consequences from the point of view of someone watching the show.
Correct. The "critical mass" if you will of bacteria needed to overcome the stomach and make it to their point in the GI tract to cause mischief is MARKEDLY decreased.Troll Bait From Hell said:...since I...take prilosec...blocking some acid...reducing the ability to kill pathogens that get into my stomach, increasing my chances of food poisoning?
I do NOT believe there are any large randomized studies to address this and provide specific percentages. However, it is well known there are different minimum quantities of bacteria required to successfully traverse the hostile stomach environment and result in intestinal disease/enteritis/etc... The minimum required number does markedly decrease if you make the stomach a less hostile environment by eliminating the acid.Cliff Stamp said:... especially if the difference it makes isn't simply a small percentage risk...
Generally and simplistically, no. Yes the amount of enzymes released from the pancrease has feedbakc control with what comes through the GI track. However, medications in the class such as prilosec/nexium (i.e. proton pump inhibitors) block acid production and this will not be offset by dietary changes.Cliff Stamp said:Can you by altering your diet do anything to offset the chance of infection as isn't the level of stomach acid and specific enzymes activated influenced by what and how much you eat. For example reducing the level of water intake to cut down on dilution...
It is important to keep in mind that there are a variety of types of "GI upset". Some food poisoning is from actual toxins already preformed in the food, some from bacteria entering into your GI tract, some from parasites, etc...it all varies.Troll Bait From Hell said:... increasing my chances of food poisoning?
UpToDate said:The infectious dose of E. coli O157:H7 for humans is only 10 to 100 organisms (which is low compared to that of most other enteric pathogens)
Shigella — 10 to 100 organisms
Campylobacter jejuni — 10(4) to 10(6) organisms
Salmonella — 10(5) to 10(8) organisms
Vibrio cholerae — 10(5) to 10(8) organisms
Enterotoxigenic E. coli — 10(8) organisms
Yersinia enterocolitica — 10(9) organisms
other general classes/types/descriptors of E. coli:
• E coli, Enteroaggregative
• E coli, Enterohemorrhagic
• E coli, Enteroinvasive
• E coli, Enteropathogenic
• E coli, Enterotoxigenic
UpToDate said:Yersinia pestis, the etiologic agent of plague
Plague is a zoonosis primarily affecting rodents...Rodents are the most important hosts...
Humans are accidental hosts who play virtually no role in the maintenance of Y. pestis as a persistent pathogen in the ecosystem. While transmission may occasionally occur by direct contact or ingestion, survival of the bacillus in nature is dependent upon the flea-rodent interaction...
Humans acquire the disease by several routes:
Bites by rodent fleas
Exposure to humans with pneumonic plague
Handling of infected animal carcasses
Scratches or bites from infected domestic cats
Exposure to aerosols
Flea bites are the most common route of transmission of plague to humans, followed by contact with infected animals. In about 14 percent of cases, the source of infection is unknown. In the absence of epidemics, plague is largely a disease occurring in wild animals, with humans being an accidental victim.
The most common animals to transmit plague in the United States are squirrels, rabbits, and prairie dogs, although undetermined species account for about one-third of cases...
UpToDate said:Bacillus anthracis, the causative agent of anthrax...
B. anthracis is a sporulating Gram positive rod. It is nonmotile and grows aerobically...
Spores of virulent B. anthracis, when introduced subcutaneously, begin to multiply. Production of the antiphagocytic capsule facilitates local spread, while exotoxin production produces extensive brawny edema and tissue necrosis.
Airborne anthrax spores... Spores between 2 to 5 microns in size are deposited on alveolar ducts or alveoli. They are...transported to mediastinal lymph nodes, where they multiply and cause a hemorrhagic mediastinitis but usually not a true pneumonia. Bacteremia and meningitis are frequent complications [17,18].
Gastrointestinal anthrax follows ingestion of grossly contaminated and undercooked meat. Anthrax bacilli are transported to...lymph nodes with the development of hemorrhagic adenitis, ascites and septicemia.
Anthrax is a rare infection in the United States....
But, that has already been adressed.LSkylizard said:...I would say that one of the worst things he did was drink directly from a puddle ringed with what he described as rat dung.do/feces....that is frightening!
