sushi knife thickness
Gevir Knives
Hand made knives out of Nova Scotia, Canada
battling between using 1/8" thick and 3/32" for a sushi knife i'm making for a friend.
i used 3/32 before for some kitchen knives , they turned ou great , but i use a charcoal grill converted for heat treat so the burn is uneven and sometimes causes warping
i know upgrading to a even heat oven would fix that but $$ is not there right now so i;m wondering if 1/8" would be thin enough
worse case i'll use 3/32 and hammer back into shape if need be but don't want to if i don't have to
Thanks in advance! I'm new to the forum and will be upgrading to a paid subscription soon, until then check out some of my stuff here.
http://www.daggerscove.com/#!knives/cccy
I assume you are talking about a yabagiba. If you are going to make a traditional style one with a chisel grind on one side and a hollow grind on the other (urasaki), 1/8" or more is typical. If you are going to do a double host grind version (basically a sujihiki with a yabagiba profile), go with the 3/32" or thinner.
Chris
If its carbon steel, after the quench past the perlite nose and while is still hot, put the blade between flat plates and a weight on top, this helps a lot to avoid warping. If its stainless its even easier because you go straight from the oven to the plates.
Pablo
Chris
yes it's the yabagiba style. i did more research ad went with 3/32 for it. i've been looking and there are a few schools on the subject. the double edge(host?) grind, and one honed side only with a asymmetrical hone. i'm going with the latter. i did a practice run on some 1/8" and it seemed a bit thick but still looks the part but it's for a client so i'll keep that one and do one on 3/32 for him
Pablo
thanks, good advice! in the past when it's happened on other kitchen knives and thin blades i just hammer it back as good as i can but it never goes 100% flat and i'm not a skilled blacksmith so there's hammer marks.
so that's immediatlety after it's out of the quench right to plates?
my single bevels are almost always right around 3/16 thick but taper to 1/8. double bevels are 3/32 at the spine and taper as i get out to the point
