Jason B.
- Jun 13, 2007
The usual advice is to use more pressure to release dulled grain, you advocate using nagura more often instead. Makes sense, the nagura is harder than any knife so it will do a better job.
Yeah I use 400 grit for 2k GS.
At that point, if I was seeking an even flatter, flawless grinding surface, I might weight cost of buying high quality diamond stones against simpler methods, i.e. SiC paper on glass (afaik Paul Seller's method). A sheet of paper is €0.30 or so, I'd have to go through 260+ sheets before the atoma (local price 80€) becomes more economic - altough it would probably more pleasant to use than fast-wearing paper.
Hm that makes sense although still quite vague (unsurprisingly bc industry secrets). Maybe the trick is to use softer sinterable elements (dk which) along with high purity alumina to get a ceramic bound that is soft enough to be used in hand grinding. I'm assuming the 'clay' used is not a naturally occuring product (low alumina content in these) or at least purified. As per https://www.klingspor.de/en/lowdown-on-grinding 'Ceramic' here apparently refers to both to the bond (sintered ceramics) *and* the type of abrasive - agglomerated grains like the type used in cubitron etc. i.e. structurally but not chemically different material.
The use of pressure to "release grains" is greatly misunderstood. Not all the abrasive releases on stones so you get a glazing effect from the dulled abrasive left on the stone. This is also the reason you can get a higher polish than the grit rating would suggest. The greater the polish the stone creates the less abrasive its likely to release. Stones that release more abrasive tend to produce duller and hazy finishes.
I use lapping and a Nagura to refresh the surface because its "used" after sharpening. I recommend this with all stones for the above reasons but even more with Shapton stones because they are very hard and the surface texture of these stones is very important.
Im sure there are lots of differences in how its done and defined but Bauxite is a natural clay found just below the earths crust and is the main ingredient in ceramic production. How Shapton does it is likely very different but they have yet to release such information.
