Guust-Fi said:
So, do you guys agree that the Swiss Tool Spirit is better than the Leatherman Charge? In what aspect exactly?
I am considering to buy a multitool and I was thinking about a charge for a while untill I found out about this new tool... decisions...
I don't OWN a charge, but I have handled them quite a bit. The charge has a better blade Steel, but most of us carry an additional blade anyway. The blade on the spirit is thin and cuts well, it will need more resharpenings.
The Charge has a one-hand opening blade. Because of the way it is made, the pivot for the blade is near the pivot for the pliers. This means that you cannot fold one handle away and use the knife as easily in 'apple-peeling' grip (like you can with the Sprirt)
If we compare the Spirit to the Charge, I think the charge is more versatile, BUT if you compare the Spirit PLUS (Which is nearer the same cost), the ratchet makes it better.
On the charge, you have a few drivers on-board and extras in the sheath, unfortunately you don't have much reach with the short driver bits.
On the Spirit itself you have more room for flat drivers, scraper etc., because the bits and ratchet-wrench are separate, but still fit in the sheath. The ratchet has more reach than the charge and can be used as a ratchet OR a thin driver.
They both seem fairly robust, and I think you need to try both and see what you like, and largely depends on how much you like/need a one-hand blade, and what bit-driver method you prefer.
I think the charge vs. spirit is a close match, but the Spirit PLUS is clearly a better solution IMHO.
