- Jan 10, 2010
I'm setting up a sword heat treat forge in a 55 gallon drum. I intend to have it sitting vertically and with a steel muffle located centrally and refractory lining the inside of the drum. The blade will be lowered into the muffle and hang during the soak. I now have a burner port located on the bottom of the drum and situated to deliver flame tangentially for a nice swirling heat around the muffle. I intend to have PID/SSR/Solenoid control of the burner. What are folks' opinion of using a venturi versus forced air for optimal heat .. i.e. even heat? I have a side arm type venturi from Zoeller that is currently not being used. I understand that it's nicer to control the blown type due to the issue of the burner turning on and off etc... but I don't mind dealing with that for the sake of a simpler control set up and if it delivers nice even heat.
Also.. I read somewhere a while ago... and now I can't find it.. that somebody was using a gate valve to control the blower fan output rather than the motor controllers. Can anybody shed any light on this option???
