omaha-beenglockin said:
Claims of extented mileage with syn's are false-----you still drive through the same dirty environment and the filter can only handle so much....
Actually, that statement is the
false one! I began using synthetics in marine diesels in the mid-80's. Now, when you're talking $50K an engine in 1985 dollars,
YOU FOLLOW THE MANUFACTURERS RECCOMENDATIONS! I can assure you there is absolutely no greater torture test for an engine than a high performance marine application. We used to check our engine oil analysis every season, and we never had a problem with the synthetic oils, and our maintenance routine went from an oil change every 100 hours to every 500 hours, which is a VERY big deal when you're changing 5 GALLONS of oil in each engine!
Most of the problems that occur with motor oils are related to viscosity and chemical breakdown which takes much longer to occur with the synthetics. We also noted slightly improved performance as well as fuel economy when we transitioned to the synthetic oils. I got an extra half knot out of the boat on the top end, and picked up an extra .1 NM/gal, considering that we burned 10,000+ gallons of diesel a season, THAT'S a VERY BIG DEAL.
Currently, all Mercedes-Benz engines REQUIRE synthetic motor oil and a sensor indicates when the vehicle needs an oil change, depending on driving habits. I average about every 9,500 miles and my wife gets about 10,500 miles between changes. Benz has been using synthetics since '98, so if there was an issue, I think we would have known by now!
