The versions will be:
1- full Titanium with three different colors for spacer and clip: grey, blue and bronze
The blade will have the swedge
The knife will have the TRE system: possibility to add the flipper.
versions will be:
2- carbon Fiber handle, with Ti spacer and clip
3- entry level. G10 handle, G10 spacer
Ti frame and Ti clip
Blade without swedge
The knife will be a normal flipper-knife. Without the possibility to take away the flipper
Gianni, grazie mille! It seemed in the video, that the G10 version had a screw put into the back of the blade as if it was possible to have the thumbdisc on it (see the bottom blade of my YT snap)... So I was a little bit confused wheter the G10 knife will have the possibility of having the thumb disc attached or not.
Do you have any pictures of the G10 version, please?
Caged bearings like Hi Jinx?
Did Gianni ever answer your question, RZ? If so, I must have missed his response.
No.
Gianni,
Inquiring minds like to know more about the TRE.
IKBS? Yes
Caged Bearings? Don't know.
Metal or ceramic ball bearings? Don't know.
Molte grazie.
Much better in terms of showing the crisp flipper action. Thanks.
However, it needs to show all angles of the knives much closer with time to digest each angle.
Gianni, Thanks for the new video.
My ideal TRE would be the following which probably won't happen:
- Full titanium
- Plain color titanium clip & backspacer
- Flipper only (no hole or swedge on the blade spine)
- No clip hole on the reverse side
I can dream!
Only the extra clip holes detracts considerably from the aesthetics and it only caters to 10% of the population.
I for one appreciate all the features of the Titanium version...:thumbup:
Can you imagine living in a country, where flippers are illegal, thumbstuds are illegal, the Spyderco hole is illegal.
AND I am lefthanded!!!![]()
Thank you Gianni. It is very good EDC knife :thumbup:With my ipad here at the show it is difficult make good video... I do hope this one will help.
- Full titanium
I can dream!
T.R.E. Three rapid Exchange, LionSTEEL
Frame-lock knife
Blade: M390 BOHLER 60-61HRC
Blade length: 74 mm - 2.91
Blade thickness: 3.5 mm 0.1378
Overall length: 175 mm 6.89
Weight: Carbon Fiber 62 gr, Titanium 74 gr
Frame: Titanium 6Al4V
Handle: Titanium or Carbon Fiber or Black G10
Spacer: Titanium 6Al4V
Clip: Solid Titanium 6Al4V
IKBS ball bearing
Stainless steel lock-bar tip
T.R.E: LionSteel Patent pending
Wood box with:
- Key ring with Torx T6 bit and Torx T8
- Thumb Stub
- Flipper
- Two more screws
CONFIGURATIONS
Full Titanium and Carbon Fiber handle:
- removable thumb stub and flipper.
- wood box with knife Key Ring and all accessory
- Solid Titanium Spacer
- Solid Titanium clip
- Titanium Frame
Price: 280,00 Euro
G10 Handle:
- Blade with flipper NON removable
- NO thumb Stub
- No wood box with accessory
- Paper box
- G10 Handle
- Solid G10 Spacer
- Titanium Frame
Price: 196,00 EURO
So if some users do not like the possibility to take away the flipper can buy the G10 version.
I did not mean it as a slight to Europeans or left-handers. On the contrary, TRE's design is very inclusive which is great.
I just posted what my optimum TRE would be mostly in the aesthetics department without the extra holes.
