- Dec 1, 2011
For sale is a New without Tags, TAG Large Advanced Loadout Bag in A-TACS. This bag is amazing, huge, and built like a tank. I've had it for about 6 months, and it has been sitting in my basement unused. It's probably too large for my intended need, so I figured I would post it for sale here. This item is huge, and I'm assuming that shipping will be at least $50-$75. This bag retails new for $699. $400 Shipped. Paypal Gift or add 3%. If you have any questions, please email me at mjergens79@yahoo.com.
The Advanced Load Out Bag is the largest and one of the most sophisticated pieces of gear TAG manufactures. After reviewing every other rolling bag on the market and using operator input we quickly realized that the problem was with the frame. TAG attacked this problem by not using a cheap off the shelf plastic luggage roller that is typically bolted to the bag. We worked with a custom metal shop and had them use 6061 Aircraft grade aluminum with thick tube walls to prevent the frame form bending or warping under heavy loads. The frame has wheel wells covering the wheels. This helps supports the weight of the bag when rolling and acts as a guard in case something punctures the bag from the inside, so the bag keeps rolling. The frame was then powder coated to ensure long lasting exposure resistance to the elements. We use a one piece solid axel for the wheels. The wheels are over sizes roller blade wheels. Rubber bumpers on the bottom of the frame are riveted in place. The frame is welded together making our frame stronger than any other in the world. We have delivered thousands of these bags to operators all over the world. Problem Solved.
The Advanced Load Out Bag is a oversized cargo bag that is attached to our roller frame. The bag is made with 1000 denier fabric for durability, water repellency, and abrasion resistance. The bag is lined with 440 weigh pack cloth for added strength. Inside there are (5) tear out bags that have hook and loop attachments so they can be stuck in place with in the bag. (2) large for the floor of the bag, and (3) small ones that line the back wall of the bag. Heavy duty YKK zippers are used on the bag. There is a zipper cover sewn in place to protect the zipper. Large cargo pockets are sewn to the outside of the bag for extra gear storage if needed. Heavy duty handles are sewn to the body of the bag. One is sewn directly onto the frame so you are not putting stress on the bag while moving it. There is also a handle sewn to the bag on the edge near the center. This handle allows you to pull the lid closer to you while zipping it shut so if the bag is over loaded the zipper will not break by accident. There are (2) clear view windows on the bag so you can easily mark and identify your bag when you get to you final destination. These bags can take an extreme amount of abuse. They are also backed with TAGs exclusive NO Questions Asked Lifetime Warranty.
