Benchmade 710
Pros:
-4 Inch blade
-G10 Scales
-Axis lock = strong = wicked fast
-Steel lined for strength
Cons:
-Benchmades 40-50 degree grind
-Heavier than most (almost 5 ounces)
-D2 maybe isn't enough but you can get in the n690 or something basically Duratech 20CV.
Spyderco Military
Pros:
-4 inch blade
-Awesome G10 scales (finely checkered)
-Light weight (almost 4 ounces)
-super sharp full flat grind making a needle tip that penetrates well
-Great jimping
-Big handle for gloved hands and impact
-wicked fast
-S30V blade
Cons:
-Not steel lined
-liner lock (albiet super strong not as good as axis or lock back)
-Tip down carry
-Delicate tip
Emerson CQC-8
Pros
-Great bladeshape with belly, strong tip and good penetration
-4 inch blade
-Titanium liners
-awesome g10 scales
-Deep finger troil makes it impossible for hand to go forward basically
Cons:
-154cm? Maybe not such a great steel value for this price point
-Heavy, 5 ounce blade
-mid spine hollow grind doesn't lend itself to EDC as great as a fullflat
-Relief cut is chiseled
Benchmade 940/941
Pros
-Super light 3 ounce blade for 3.5 inch blade
-Reverse tanto is a great balance of tip strength, belly, and penetration
-S30V blade
-Strong construction with titanium back spacer and aluminum steel lined handle
-Wicked fast and strong lock
-Slender and easy to carry
Cons
-kinda slick handle vs G10
-Not super ergonomic feeling compared to the rest (slender no deep cutouts for your fingers)
-narrow blade doesn't lend itself to sheering as well as the others listed
There is way way way more than just this.
