- Feb 1, 2004
Could someone please clarify what the differences in these categories are? To me there is no such thing as a tactical-utility knife, because to be separate from a pure killing knife it must have better intrinsic utility value already. The perfect killing knife is a boring thing, probably spring soft steel with a dull tip so it won't stick in bone (soft so it won't shatter)... And fairly dull to induce pain on slices. And it doesn't need to be sharp to stab anyway...
In other words, a screwdriver, although ideally it would be wider to enhance bleeding.
I hate how makers call their knives tactical, or tactical-utility, but when it fails critically in tests designed to test its tacticleness
barf
or utility value they quickly scatter backwards and claim that its a knife designed for killing/slashing only. Prying in soft pine shouldn't break the tip off of a "tactical utility" knife! A prison inmate with an IQ of 80 can make a killing knife why should we pay $799 for yours?! Does it kill them more dead or something?
Whats even worse is when a maker advertises their knife being able to chop through concrete blocks, pry your way out of a helicopter, chop your way out of a car etc, only to see it fail doing these exact things which a kabar could do without shattering... Then inevitably slander and verbally abuse the person who simply did what it was advertised as being able to do.
What if you were in the military and trusted your life to one of these blades, and died a fiery death because of false advertising? Really sickening.
Anyway, there is a purpose to this thread. I want people to outline exactly what they think a tactical knife should be, and be able to do without critical failure.
For example:
Over 6 inches blade length
Strong enough for a 250 pound man to do pullups on
Able to withstand batoning from a metal object
Able to chop through a concrete cinderblock
etc etc.
We need to establish a battery of tests that are repeatable, to determine if a makers entry into the tactical market is really worthy of its name.
Another layer of complexity, are there different levels of tactical? Is anything less then a heavy duty tactical really tactical in a fixed blade, or could its role simply be filled by a utility knife.
For example:
etc etc.
