I’ve had a few of Tactile Turn’s bolt-action pens. The quality and machining is phenomenal. If his knife shares the same attention to detail and precision that his pens do, I’d say $300 is a bargain by today’s standards.
I’ll be getting one of these.
My thoughts exactly, after owning 4 Tactile Turn pens, which are beautifully machined, among the nicest "tactical" pens out there IMO, especially in lightweight titanium.
There are a number of Rockwall reviews on Youtube to help you make the choice ... the Quiet Carry Waypoint is a similar design.
I bought both.
I really like the Rockwall flipper:
* Handle machining is excellent, quality touch.
* Nice design, feels good in hand, except for the back edge of the pocket clip which I chamfered with a 1500 grit diamond stone, and that helped but this area could use some work.
* The flipping action is very good, the lockup is also, with lock bar fully behind leading edge of lock face.
* I like the blade shape, a drop point with a swedge, with some belly, and it came very sharp.
* Blade is flat ground, fine bead blasted finish.
* Stain Resistance: CTS-XHP is at the low end of the stain resistance spectrum for a stainless (it's a couple clicks better than D2, which helps a lot, but is not in Vanax league at the top of the pyramid, IMO).
* The overall weight is pretty good for the size: 2.6 oz gets you 3.0" of blade (reasonably efficient).
* I think it's a keeper.
I also have the Quiet Carry Waypoint, and overall I like the Tactile Knives Rockwall somewhat better. But I think the Waypoint is also a keeper and a reasonably similar size and design you should compare to the Rockwall before buying. I like the hollow grind of Waypoint, in this sized knife, I like Vanax (although Magnacut is poised to steal it's thunder), and the satin finish version is really nice. Personally, I like satin finish better than bead blasting or stonewashing, but that's just personal preference, the stonewashing often wears less noticeably. Waypoint is super-stainless, stem-to-stern, by design. I like the Rockwall flipper better than the thumb stud opening on the Waypoint.
