- Feb 3, 2001
Well I started to dig into one but was thwarted by loctite once again. ......
Ever try 5 minutes of boilin' in water to loosenin' Loctite, just make sure the other materials in the knife can take the 212 degrees F, also I've used a solderin' iron on pivot screw to break Loctite down.
Just two suggestions to break the screws loose.:thumbup:
BTW when you reassemble use the Loctite that's removable it holds tight but is a lot easier to break loose.:thumbup:
