- Sep 29, 2008
why 5 bushings ?
A lot of knives use thread-lock which will make the screws extremely hard to loosen - that couple with the fact that torx heads are relatively easy to strip compared to flathead or Phillips makes it very hard to get some of the out.
In my experience with enough downward (into the screwhead) force while turning they can be gotten out without stripping the head. However, there are a few can't manage to get out (the torx screw on the thumbstud thingie on my CRKT Horus). Idk if they make such things - but an impact driver with precision bits would be the way to go.
TORX are harder to strip, you just have to use the properly sized driver.
I hate Phillips head screws because it's hard to properly tighten them unless you have a perfect fit with the screw driver. TORX was designed to not have the bit turn out of the screw head while Phillips was. It was a cheap way of torque control.
