Talk to me about Knives and Pocket Organizers
As convenient as these [fanny packs] can be, they are often the butt of jokes.
I see what you did there (ahem).
My solution is to spend 5 minutes with a sewing machine and to stitch a seam up my right rear pocket on all my pants. About 1.5" from the outer edge from the bottom and about 2.5" up.
This rear pocket keeps a large folder sitting upright along the outer edge of the pocket.
Carried here, the knife can't be felt when sitting. It's generally invisible, particularly if you wear Dickies or similar. It's also very easy to access the knife here.
I regularly carry a Buck 110 like this, to give you an idea of size capability of this approach.
I picked up this cheap $15 dollar job on Amazon just to get the feel for how these type of things worked for me. I prefer going with a craftsman whenever possible with these types of items, and I do plan to look into Hitch & Timber or similar at some point, but for the price I thought this was a good option if just for research before making a larger investment. I really only need it as a place to stow my traditional carry knife for any given day (I keep a modern folder clipped in my rf pocket), and the less bulky the better for me. So far it has worked well, and I've carried it daily since buying. It has an extra pocket that I use for keeping my key fob from being loose in the pocket and a pen loop which I don't use because I prefer to keep my pen clipped elsewhere. One thing I like about this one that I might dislike in a more substantial one is that it is flexible. I can slightly bend it in the middle allowing the knife to be towards the back of my pocket more on the side of the leg while the rest curves around my leg. This makes it print much less than if it were just a stiff rectangle (not sure if I explained that well). I carry this in my left (weak hand) pocket for reference.
Here’s one I made from scrap leather. No sewing required. It’s just woven together with paracord through holes punched in the leather (small cuts would work as well if you don’t have a hole puncher). Here it’s shown with a disposable lighter, firesteel and a single-AA flashlight. I rotate what I carry in it as needed, often including an SAK Farmer or a small lockblade. The whole thing vanishes in a front pocket.
Another thought for your buddy is to hang a knife inside a front pocket from a tether attached to a beltloop or belt. I do this as well, sometimes, as I can’t stand a heavy knife loose in my pocket.
I'll add that the same thing can be accomplished with a safety pin or two. Not nearly as permanent and can be removed in seconds. I have a few pairs of pants I do this to in the LRP so I can carry a slim but tall MT there.
No clue what the options would be for a modern folder.
I'm going to bet that it works just the same as with a traditional, you just have the option of a clip as well.
Is there a way to contact Allegory Leather other through Massdrop; which is a hassle.
......- just have never used massdrop - even though I've tried several times - always seems to be a hassle.
Sometimes I wish it was MORE of a hassle. "One click and it's mine" can get expensive.
Here is the little Quick Draw I use for a Bic lighter and mini multi-tool. They make a few different designs. This material is thinner and more flexible.
https://www.etsy.com/listing/736470499/the-quickdraw-mini-edc-slip-case
I don't care about pen loops either. I always wear shirts with pockets. That is where my pen and Field Notes live.
The pocket-shaped ones are going to work better, even though they're harder to find. Rectangular orgs (like everything from MaxP, unfortunately) gradually rotate inside your pocket, until they jam against your leg or something, like trying to carry a couch up a flight of stairs.
Get the thinnest, most minimalist one that you can find. Skinth makes a quality product, but they're very bulky, once inside your pocket. You start adding flaps and zippers, and you will end up pulling the whole thing out every time you want to trim a hangnail.
Do not give in to the temptation to over-accessorize! What's in your pocket without the organizer is what should go in the organizer, and nothing more. It's easy to think that more pockets equals more better, but it just makes it impossible to retrieve anything that you put in there. The rest of it goes in your Vanquest or Saddleback messenger bag.
You guys talked me into this. I've been looking for something to carry my mini tools and this is perfect. Left to right: ceramic rod, Opinel mini steel, Channellocks, Crescent wrench, Vice Grips, Victorinox Tinker, pencil. Paper in back and rechargeable LED flashlight at top. (All the tools are name brand.) Room for more; I may put a small Rough Rider lockback in one of the pockets. :D
I put a mini first aid kit in one of the back pockets of mine
Great idea!
Thanks.
It’s not much. I figured why pull out a full-fledged first aid kit with all I need is something minor.
How many times have you opened up a first aid kit only to find all the kit for minor injuries is gone? Having a mini first aid kit as part of my EDC bag Can keep things like this from happening.
I still go through and inspect the aid bag and first aid kits twice a year. In October and in May (my anniversary and birthday).
Thanks.
I still go through and inspect the aid bag and first aid kits twice a year. .
Same here
After seeing Knives&Lint post a picture of his, I went and bought the larger one. I think it's listed as "XL", cost about $16
It's 100% leather and will fit two medium sized knives perfectly ( or a knife and flashlight/small multi-tool).
You can probably go up to a Buck 110 , it does fit.
