Don't use 3 jaw drill chucks, keyless or otherwise, for holding endmills. They are not designed to withstand radial (side) loading.
It can be done in a pinch, with small endmills and very very light cuts when there's no other option to accomplish what you need to do, but it's not something you want to plan on doing.
Use collets or endmill holders like the count recommended. FWIW I've been machining 20 years and have always used collets in small manual machines. It's been rare that I have an issue doing so. It can happen, for sure, and an endmill holder will allow you to get the full removal rates the tool and machine are capable of, but it's never been worth the cost to me.
Little Machine Shop has a closeout right now on a 4" milling vise. Only $65. I bought one for my big mill. https://littlemachineshop.com/products/product_view.php?ProductID=1504&category=
Dude, considering I know where you live, and I've bought most of my machinery at insane prices from your area, I'd highly recommend you consider a full sized knee mill, unless there's some caveat I can't fathom. A Bridgeport won't take significantly more floor space, and will handle a lot more than any of these import mills of this type, and if you're patient, you'll probably save money.
Yes, weight matters. When it comes to machine tools, the rule of thumb is nearly always accurate: heavier the better. Most American made machine tools are/were built much heavier in weight than strictly necessary, because rigidity has a direct and very real affect on accuracy.
Even for knife work you can see the difference between a good mini import mill and a decent domestic mill. Night and day between a really tight domestic mill and the best import. To be fair, you can absolutely do great work with a machine like you linked. It'll just take more care, and more patience, and unless there's some specific reason to go that route, why? Some of the full sized imports are quite decent also, and I'd definitely take any real knee mill over a bench/mini like the linked type.
I'm sure everybody that has one of these types of mills is going to feel insulted. Not my intent, but hopefully we can all agree that they have limitations, simply by design.
Even if you're not an expert on machine tools, you can pretty easily tell the difference between a really nice machine, and a potentially bad one. On top of which, I'm close and willing to help you. I'm actually going to be in your area looking at a surface grinder soon, and the owner also has a very nice looking Enco Variable head with DRO. This is an import bridgeport clone. Not as nice inherently, but if he's taken care of it, comparable to a Bridgeport that hasn't been taken care of, if it's Taiwanese especially.
Wouldn't it be more advantageous to get a keyless chuck to take the place of the end mill holder or is there a disadvantage to using it?
I'm sure I'll be ordering many things in the coming years lol. But right off the bat I was going to order the following (if you guys have advise for or against these I would love to hear it):
Anything I'm missing right off the bat? Dial test indicator or parallels or will those be fine at a later date? I did find this thread on tuning the PM-727, looks like he had a bit to do - hope mine won't be that bad but if it is I know the customer support will be there (unlike grizzly!)
- Precision R-8 Collet Set (I know you are recommending the endmills w/ weldon flats and endmill holder instead Count) - so maybe I should skip these?
- Clamping kit
- 5" vise
I highly recommend the Dial Test Indicator and Parallels you will need both for setups.
Kuraki is right about collets and starting out Little Machine Shop is a good place to shop for specials.
As Kukri said, chucks are for drilling.
Drill shanks are softer, end mills are hard - endmills will spin and kill the chuck jaws.
You still need the collets-at the very least to hold the edge finderand the indicator-the price on that PM set is reasonable-USA made are 45 each.
Tom Lipton is a proponent of putting short fixed straight shanks on his drill chucks for quicker transitions - from less head movement.
https://www.amazon.com/Metalworking-Sink-Swim-Machinists-Fabricators/dp/0831133627
https://www.youtube.com/user/oxtoolco
You will use parallels in the vise-probably right away
Re that 5 inch vise - There's a chance it's too big for that machine, the 4 inch Kukri showed may be good
You can also go smaller with a toolmaker type vise
http://www.shars.com/3-x-5-precision-toolmakers-vise
The dial test indicator is how you will tram in and line your vise up straight.
There is a video series by
AGI-Milling Machine-Darrell Holland.
It's expensive, but you can find downloads.
You can learn a lot on setups from good YT machinists
Stefan Gotteswinter
Tom Lipton-ox tool
Adam Booth
Robin Renzetti
Tom's Techniques
If your pocketbook and space allow, get at least a Bridgeport sized mill. 475lbs for a mill does not equate it as being a "beast". My 800lb gear head mill has been relegated to mostly drill press work due to its lack of rigidity, and inability to "geterdone!". I went from the small to a medium to a "full sized" mill, before finally settling in. Don't forget that just because you are purchasing a mill for your bladesmithing doesn't mean that will not find a multitude of other projects for it. My suggestion? Go big w/ a 3 axis DRO.
Josh,
Yes both the parallels and Dial Test Indicator will work fine to get you going...use your calipers to check the parallels they should be spot on but import tools can catch you off guard on quality. When you stash some cash step up to one of the other Indicators I mentioned earlier...They are Dead Nuts On Precision and yes you get what you pay for...saves on Hair Loss from frustration also![]()
as to the belt vs gear drive my mini mill was gear driven (till i broke the plastic gears) and a bridgeport is belt driven
the belt conversion on the mini mill gave me more RPM at the cutter so it was better able to run the smaller endmills at proper speeds and cut down on noise was a nice thing too
Butch,as to the belt vs gear drive my mini mill was gear driven (till i broke the plastic gears) and a bridgeport is belt driven
