- Mar 29, 2007
The Nessmuk trio is a well known standard of carry for the wild. I have tried it in various forms and come up with my own preference, which isn't even a trio!
Nessmuk's classic pattern utilizes a small to medium fixed blade knife, a folder, and a double bitted belt axe with two different grinds. I depart from the classic in every instance-
First, there's the axe. I vastly prefer a decent chopping hawk with a good hammer poll. Since my time in the wild often includes actual camping, the hammer poll comes in very handy. It's also useful for wild country or rural EDC type carry- I've often used my CS hawk to hammer nails in the yard or at a remote jobsite I worked at. The primary thing lost is the fine ground edge on the nessmuk double bit. But as we'll see, that's not such a loss, in the end.
Second I want to address the folder- I see this as a very useful item. If I had to lose everything but one, in all honestly I *might* want it to be the Victorinox Outrider that I keep.
In most modern circumstances- from at home or bug out disaser utility, to woodcraft, it's a winner. The scissors are - if not essential- very very useful. Probably the most used item on any SAK I own. Then there is the saw. Being on a lock blade SAK, it's a touch longer than the 90mm SAKs, and very useful. The corkscrew, bottle opener, can opener all get used often in regular every day life and all came in very handy last winter when the power went out for several days. I use the phillips and regular screwdrivers pretty much daily, as well.
I sometime go with a leatherman type tool, as well, and it wouldbe hard to go without pliers of some sort, but if I had to, I'd take the outrider.
Nessmuk's trio finishes with the classic nessmuk knife. Here is where I end up with a trio of four. The first part is a larger fixed blade. There are several reasons why I choose a 5.5 inch leuku pattern bushcrafter here- first is food prep. And really, honestly, a huge amount of what you do in camping, hiking, and outdoorsy stuff that lasts more than an hour deals with food. I'm a lot happier processing food with a slightly larger knife and a thin spine.
It's also big enough to chop effectively, can baton through anything, and makes up for that lost fine grind bit on the hand axe.
Because of the SAK - whose blade I don't really care for for whittling, and the size of the leuku, I add the fourth element to the trio. In the past, and even now in the shop, I've carried a necker that is very small and light- I love it dearly and it's a fine patch knife and general cutting knife. But I'm working out a neck version of a small woodcraft, or carving knife. I think something with a solid handle and a 2.5 inch blade is ideal here, and adds the finishing touch to a set of tools that could take me through a homestead in the bush, if need be. This is also the only place I really prefer a scandi grind.
