Cliff Stamp
BANNED
- Oct 5, 1998
dannyvi said:Is cobalt same as talonite and stellite? I have a large carbon fiber REKAT talonite folder( Simonich?) and also a cobalt Boye folder and they are both great cutters.
Boye uses cast Cobalt 6B, it is much softer than Talonite which is age hardened 6BH, what is usually called Stellite is Stellite 6K, which has 0.5% more carbon than Cobalt 6B. They are similar in some respects, different in others. Boye's for example is much softer and weaker, and Stellite 6k is significantly stronger than Talonite as the above materials data shows. They are all much weaker than even low end cutlery steels. How a knife cuts is largely irrelevant to the alloy at a given profile. The more durable the material in general the thinner it can be ground so the better it will cut. The low hardness and strength of the cobalt alloys demand heavier cross sections for a given task. Steve Harvey was the first to note this with an attempt to cut a piece of thick plastic which removed a section of the edge on the knife.
-Cliff
