I have a used Fenix PD31 and Olight T20. Both have wear but work great.
Will take SOLD shipped for both using paypal gift for payment.
Info below about each light
-The PD31 Flashlight by Fenix is a high tech and rugged LED light that is perfect for nearly any lighting needs. The PD31 operates in two modes and has six brightness levels. At it's highest setting it can cast a beam of 304 lumens a distance of 140 meters. On the lowest setting it can run for up to 200 hours If you are looking for an all around solid, reliable, digitally regulated and compact flashlight, the PD31 is perfect for your needs. It has an anti rolling design and the durable Type III hard anodized finish makes it capable of standing up to everyday, heavy use. The PD31 is water resistant to IPX-8 standards and runs on either two CR123A or one 18650 Li-ion batteries. The nice thing about the 18650 is that it is available in a rechargeable. The PD31 by Fenix will quickly become your favorite flashlight.
Features and Specifications:
Cree XP-G LED (R5) with a lifespan of 50,000 hours
Uses two 3V CR123A batteries (Lithium)
120mm (Length) x24 mm (Diameter)
the inner diameter of the tube is 18.8mm
64.4-gram weight (excluding batteries)
Reverse polarity protection, to protect from improper battery installation
Tail cap switch
Capable of standing up securely on a flat surface to serve as a candle
Made of durable aircraft-grade aluminum
Premium Type III hard-anodized anti-abrasive finish
-The Olight TACTICAL T20features five levels of output. The Tactical version also features a redesigned switch with a momentary feature at half-press and a redesigned body optimized for the cigar / syringe / Rogers hold alongside a handgun. The Tactical also offers a lockout feature to prevent accidental activation.
Easily operated, the various Illumination levels are adjusted by twisting the head. The Olight illumination level memory saves the last level used before the light was turned off, returning to that level when the light is turned back on.
Digital regulation using the constant current technique means that output at every brightness level will be constant not fluctuating with battery life. Additionally the constant current technique means greater efficiency for longer runtimes and the most effiencient usage of the battery.
The T20 will flash to warn you when battery power is low, giving you the opportunity to change batteries or adjust to a lower output level if you need more illumination time.
The Olight T20 TACTICAL utilizes a unique linear pattern for brightness adjustment; which is different from traditional PWM used by many competitors, to do away with the strobing effect some users can perceive.
Specifications:
Uses 2 X CR123A batteries - primary or rechargeable. (not included).
Ultra Efficient, State of the art CREE 7090 XR-E Q5 WC LED 220+ lumens on high!
Forward tactical click switch.
Unique half smooth, half orange peel metal reflector ensures a smooth beam and excellent throw.
Specially designed for waterp resistance and anti-roll.
AR coated glass lense.
Aluminium alloy case with MIL-SPEC Type III black hard anodized finish.
128.5mmx21.6mmm, 68.5g.
