- Nov 6, 1999
Guys, for what it's worth, I have used the technique described in my tutorial to taper tangs down to the thickness of a razor blade. It works for me.
Originally posted by Coyotee
The only concern I have about doing any major grinding such as the flat grinding the taper after heat treating would be the heat build up and the possibility of developing stresses which could cause warping or stress cracking.
Originally posted by rlinger
Here: http://www.customknifedirectory.com/CKD_Mainframe.htm?CKD_tut_tapertang01.htm~main
I went ahead and found it. This is the one I learned from, except that I use NO wheel platen AT ALL. All I use - as stated in my post above - is the flat platen. My very first taper turned out just fine following his instruction. The one thing that requires, for me, the most practice is getting the tapers stopped at the correct position (end of ricasso). It is easy to extend beyond end of ricasso and into the actual cutting area so that the two distals, tang and blade, are not perfectly balanced.
RL
