- Sep 16, 2002
I decided to give tang tapering a try and I'm following this tutorial (which is about the only one I seem to find when I search):
http://www.robbrownknives.com/tutorials/tangs/
It doesn't totally make sense to me, so I have a few questions.
-Once I've hollowed out the tang in line with the drop at the butt and then in line with the straight'ish part of the handle, am I to then run the hollow in a straight line all the way to the butt? (Images 4-6 in the tutorial)
-Is there a rule of thumb as to how deep the hollows should be before beginning the taper?
-When I grind the actual taper, do I hold the blade straight up and down (same axis as in the hollowing of the straight part of the handle) on the platen? This seems like the logical way to me, but it also seems the dropped/rounded butt will be of unequal thickness as a result...
Thanks for any assistance!
