Tank007 E13 flashlight is a mini portable led keychain flashlight with pocket clip provided, weighs only 10g, very easy to carry everywhere, can be used as an emergency light. It is powered by 1*AAA battery, which is easily obtainable, but with 120 lumens brightness. It is switched on by simply revolving the head, with one mode design, easy to operate.
Tank007 E13 is well protected, resistance to falling and waterproofing are inherent characteristics. 1*AAA battery is enough to make it last more than 1 hour of lighting. Especially small, such as the usual small clips. If you go out or camp, it is very convenient to hang on the bag.
Main Parameters:
LED: Cree XP-E R3
Light Source: 3W LED
Power Source: 1*AAA battery
Power: 10W
LED Lifespan: above 50,000 hours
Max Brightness: 120 lumens
Beam Distance: 80m
Input Voltage: 0.8 - 3.7V
Output Level: one mode
Burn Time: high light - 0.6hours
Waterproof: IPX-8
Anti-drop Height: 1.5m
Product Features:
● Mini Portable
E13 is a very small flashlight, like keychain.
● Aluminum Material
Using aluminum material, it is non-slip, waterproof, and abrasion resistance.
● LED Source
LED will give you stable and bright light, nonthermal radiation, safe and reliable.
● Small but Powerful
● Convenient for EDC
Keychain and clip can attach E13 to pocket, bag, belt, hat or anywhere you want.
● Simple Operation
● Wide Usage
It is suitable for camping, fishing, hunting, hiking, searching, working. Thanks to its much portable feature, it can be with you anywhere to work as an emergency light.
This mini keychain flashlight has a small body but contains great energy. You can go to GearVita to feel its charm: https://gearvita.com/tank007-e13-mini-portable-flashlight-120-lumen.html
Related products:
https://gearvita.com/olight-i1r-eos-led-keychain-flashlight-130-lumens-rechargeable.html
https://gearvita.com/nitecore-tini-rechargeable-led-keychain-flashlight-380-lumen.html
Main Parameters:
LED: Cree XP-E R3
Power: 10W
Beam Distance: 80m
Waterproof: IPX-8
Product Features:
● Mini Portable
● Aluminum Material
● LED Source
● Simple Operation
● Wide Usage
Related products:
