The Tank007 E18 flashlight is an ultra compact everyday carry torch which can deliver up to 180 lumens on the highest setting.
It can be powered by one CR123A lithium non-rechargeable battery, or one 16340/RCR123A rechargeable lithium-ion battery. Two brightness settings and strobe are available, which are cycled through using the simple twist switch head of the torch.
The tempered optical lens lens that sits in front of the Cree XP-G R5 LED combined with the orange peel aluminium reflector provides a beam range of up to 100 metres.
Weighing only 19 grams and measuring 65 mm in length, you won't even notice you've got this handy piece of kit in your pocket.
Main Parameters:
Luminous Flux: 180lm
Throw Beam: 100 meters
Lens: Tempering optical lens
Construction: Waterproof to IPX-8 standard
Impact Resistant: Anti-drop height of 1.5 meters
Battery Quantity: 1 x 16340 or 1 x CR123 battery
Input Voltage: 0.8V - 4.2V
Burn Time: High light for 0.8hours, low light for 2.5 hours
Product Features:
● Candle finger-sized, very convenient to carry on with a keychain, when you travel, outdoor, camping ect.
● Using aluminum material, it is non-slip, waterproof, and abrasion resistance.
● Powered by 1*CR123 or 1*16340 rechargeable battery.
● LED will give you stable and bright light, nonthermal radiation, safe and reliable.
● Anti-slip pattern on the light head, convenient to secure grip and switch mode.
● Head rotation switch, which is durable and easy to operate even with single hand.
● Six square light anti-roll body, it will not roll on flat surface.
● Capable of standing up securely on a flat surface to serve as a candle.
● Constant current circuit chip maintains constant brightness.
● Waterproof to IPX-8 standard, anti-drop height is 1.5 meters.
● Three modes of lighting can be applicable to your lighting requirements for different environments.
● Mode selection: rotate head repeatedly to select the mode needed. Then light memorizes the last mode which continued for at least 2 seconds. For example, when you switch the mode to low light, keep it for at least 2 seconds, and then restart the flashlight, you will get the low light again.
GearVita offers this compact flashlight for you: https://gearvita.com/tank007-e18-camping-flashlight-180-lumens.html
Related products:
https://gearvita.com/tank007-e10-outdoor-mini-flashlight-120-lumens.html
https://gearvita.com/tank007-ec01-mini-magnet-flashlight-400-lumens.html
Main Parameters:
Product Features:
Related products:
