Actually the "stab" or thrust marks are pretty definite.
The exercise demonstrates how truly difficult it is to try to twist as you withdraw in such a manner that a definite "comma" is actually attained.
The reason this happens (or fails to happen) is found in the sparring exercise (which is where you can test and evalulate all the nifty cool things folks advocate in terms of technique to see if they really work). People move when they're fighting, and move real fast when they're trying to kill you and avoid being killed by you.
A proper coring with a blade best occurs after you've delivered a solid thrust that has gone in deep. As you withdraw the blade you begin the twist inside the full depth of the wound channel, coring the wound itself as the blade is pulled free.
Again, people move even - and especially - if they've been hit hard. So a solid coring also best occurs when you have really hammered the opponent and have him somehow stunned, held, or pinned long enough so you can safely (fraction of an instant) withdraw the blade in this manner.
Comma cuts, or coring/gouging, is essentially a pain inducer or distractor. It requires great finesse to pull off, as does any meaningful technique in any martial study. Again, spar it and make your own determination of the concept's value to what you might do, or not do.
If it works for you, keep it and master it. If not, then lose it and be glad you discovered what is valid for you on the basis of working the technique in training, and not in battle.
Yes, I like the straightforward approach to taking an opponent out. Sifu Paul Vunak spent 3 days with me many years ago now. He taught me the same program he originally developed and taught to SEAL Team SIX.
Size up the opponent as to his fighting style and capability - This must be done swiftly and is accomplished before the first blow is struck.
Deliver a distracting strike, most often a low line kick to the shin, as you begin your attack / entry.
Immediately shift into full forward pressure in conjunction with the straight blast.
Close the gap and begin delivering head butts, knees, and neck manipulations all in one fluid burst. Throw in elbow strikes to the head, face, jaw.
Finish by taking the opponent down (neck manipulation - where the head goes, the body must follow) and applying finishing strikes if necessary.
If you train this sequence and these strikes hard it is a pretty difficult system to defend against to any degree. Throw in a knife during the straight blast and feed it into cuts, slashes and pommel strikes as you're manipulating the head, delivering elbow strikes, knees, and head butts...
