I have two questions about tapered tangs.
How do you grind a tapered tang? I had thought to cut out the rough profile, with no curves, then drill the holes for my pins to use for alignment later. Next I would mark the taper on the edges then grind down most of the way with my angle grinder and files. I would then finish by grinding the tang against a piece of sandpaper held on flat surface. Lastly, I would mark the profile of the knife, using the pins holes for alignment of the pattern, and cut or grind it out.
Is is neccessary to compensate for the angle of the tapered tang when drilling holes for the pins in the scales? My scales will be made from sheets of paper micarta. I was going to shim the butt end of the scale and tang combination by the amount of the taper when drilling using a drill press. Otherwise, I would imagine having to drill the holes oversized or bend the pins just right.
Any suggestions that would improve or simplify these processes will be greatly appreciated. Thanks.
Phil
Phil
