Sorry, I knew that was too simple.
Here's how I do it all. Have a seat.
I first drill all the holes in the blade (just the blade, not the bolsters or scales). In my case I use three 1/8" holes for the bolsters, two 9/32" holes for the 1/4" mosaic pins I use in the handle, and one 9/32" hole for the thong hole liner.
I then taper the tang, grind the blade, heat treat, finish, etc.
When I'm ready to mount the bolsters, I cut two slabs (1/8" or 3/16") of 416SS longer than the knife blade is wide. I drill through the blade holes into one of the bolsters, matching those three holes. I then use that bolster as the template for drilling the other bolster. Then I finish up the forward and rearward surfaces with the bolsters held together with loose pins. This makes them match exactly.
Then I put the bolsters on the blade. 3 pins usually require a little pushing to get them through both bolsters and the blade. That done, I cut off the excess pins to about 1/8" on each side. Using a 4# hammer, I bang the hell out of the pins until they virtually disappear. OK, now the bolsters are on and even.
Next I epoxy one of the handle slabs to the tang, snugging it up against the bolster. Once set, I drill three 1/4" holes for the pins and thong hole liner. I also trim the mounted scale so it is about the size of the tang. (This makes the later finishing a lot easier).
Then I epoxy the other scale to the tang as before. Once that is set, I drill back through the first scale holes and through the second scale. I epoxy the pins and thong hole liner in place.
Once that is all set up, I trim everything with a saw, and begin grinding it all to shape, bolsters and handle slabs together. Doing it this way is pretty certain to get everything to fit and line-up.
This is a whole lot of making a knife in a few sentences. If this still doesn't make sense, feel free to email or call me.
If I got close, ask more questions.
In any case, good luck.
Jerry Hossom
www.hossom.com
[This message has been edited by GaKnife (edited 02-19-2000).]
