Busto
- Jul 26, 2011
Daniel..........if you use the same thickness material on a regular basis you can save time by using a shim under the material to set your depth (I use a 0.040 shim) that should raise your material to be tapped set your tap to the top of the material and set depth stop remove shim and you're ready to tap away.
Mike
Mike
