View attachment 981743 You can also use hand tappers. They don’t take up as much space as old drill presses.
Admittedly, only done this on holes over 1/4”. Concentric alignment was just with the tap nosing slightly thru the nut. Clamping was done with c-clamps or pressing between teeth of an excavator bucket.The nut method may be useful in the future, but how do you get it centered exactly? Do you use the nut as a guide when drilling the hole and then use it again to guide the tap?
I want one, where did you get that?
Edit
Wow, i found some of these tappers for $600! Most are $150-$200. I think i will try to find a used one.
The one in the picture is a Cedarberg. The smallest collet runs all the smaller sized taps.I want one, where did you get that?
Edit
Check out Little Machine Shop...they sell a Mini Hand Tapper.https://littlemachineshop.com/products/product_view.php?ProductID=2898I want one, where did you get that?
Edit
Use a drill press to drill a straight hole
Stop buying taps at hardware stores. for some reason, they all sell plug taps
They are made to clean out a thread, but not to start a new one
I like spiral point taps, but a get a HSS taper tap it will start easier.
As was said, drill the hole in a drill press, then use the setup to guide the tap straight.
Well, I guess I've made at least 2000 folders the wrong way. lolDO NOT USE A TAP IN A DRILL EVER.
spooky skill right there as i break 2-56 taps when hand tapping |TiI just use a cordless hand held drill for 0-80 & 1-72 taps. Really I do.![]()
I used to brake em when hand tapping also, but not since using the drill. Around 20 years now.spooky skill right there as i break 2-56 taps when hand tapping |Ti
Speed helps too, zip em in & zip em out. .
Yes Karl, I don't listen very well.You must not have listened when somebody told you not to do that.![]()
From what I have read about tapping titanium, that IS actually how you should do it. Although a drill press/mill would be a safer bet so there is much less lateral stress on it.I chuck the taps up on the round part of the shank, not the square end. This way they slip before they brake. Speed helps too, zip em in & zip em out. I'm usually tapping Ti between .040 -.070" and Damascus.
