One or two sizes larger drill works great for ti. I stopped breaking taps when I started using a elec drill/driver to run the taps. Zip em in, zip em out, fast and no breaking. I use mostly 0-80 and we all know how easy they break
I agree with Don. I use a cordless drill to tap 2-56 in titainium. I no longer break taps, I wear them out. Roger Hatt showed me this about a year ago and been using it ever since.
Spiral ground high speed steel taps from Kit Supply is what I use.My main question, especially to Boatbuilder and Don who use drills for their 2-56 tapping ... do you know / remember exactly which taps you used? I've broken about 6 taps so far tapping by hand and it's probably because I have the wrong taps (and was using the wrong drill size). At $20-$50 for the taps that are recommended on the other forums, I'm hoping you can tell me the exact tap to buy. Also, how do you secure the pieces you're tapping? I would really like to minimize any trial and errors on my part.
This is what a small hand tapper looks like. It solves the off axis thrust problem. I remove the blade when tapping, so I am tapping a through hole. The pictured tap is #2X56TPI.View attachment 704328
I hold the liner in left hand and drill in right and am done in 1 or 2 seconds. I use 0-80 & 1-72 taps & rarely break one. When they start acting dull I toss em. These cost like $2 each I think, it's been a while since ordering any cause I'll get 2-3 dozen at a time.
From my research, I've learned that Brian Fellhoulter (surely you guys know of him) uses (or at least used to use) one of the TapMatic drill press add-ons. They look incredibly useful and knowing that Brian used one adds a lot of credibility to them. I've seen a lot of people say to stay away from them, though. Admittedly, I haven't done a lot of research into them yet.
Thank you guys. It sounds like I don't need the fancy expensive taps but I've broken so many $8 taps that I'm leary of the cheap ones.
Do you guys use any cutting fluid like Moly-Dee? Literally everything I've read says to stay away from Tap Magic when tapping titanium and strictly stay with the Molly-Dee.
TiGuy7, have you broken many taps with that hand tapper?
Don, when you use your drill are you going full speed or do you throttle your speed at all? I saw one that guy that built his own hand tapping machine like TiGuy7 uses and he made a 1/4" shank for it so he can use his drill.
Thanks for your help guys.
I run the drill pretty fast, but not much over 1/2 speed. I also use a wax type lube made for burrs. I think it called Burr life? That said, the thickest ti I tap is .070". All free hand with a cordless drill. Hundreds of holes per year. Maybe break one tap per year or less. Have you ever looked at a 0-80 size tape? I used to break em all the time doing it by hand.Don, when you use your drill are you going full speed or do you throttle your speed at all? I saw one that guy that built his own hand tapping machine like TiGuy7 uses and he made a 1/4" shank for it so he can use his drill.
