Used and in perfect condition, Targus Defcon 1 PA400U security device with all the hardware to make it work with any modern laptop, plus a zippered case for travel. This will work with luggage or anything you can run the cable through. If someone tries to remove it, it starts beeping-- it senses motion too. Also included is a padeye to permanently install on a desk or other hard surface to lock down a laptop using this device or a security cable. $15 including shipping and PayPal fees. Email dwambaugh at yahoo dot com.
Factory blurb (see http://www.targus.com/us/product_details.asp?sku=PA400U )
* Easily attaches to your carrying cases, luggage, or notebooks equipped with a security lock slot
* Retractable steel cable retracts into plastic housing at the press of a button
* Re-settable 4-digit combination lock- up to one of 10,000 unique combinations available
* LED indicates alarm status
* Alarm is activated when cable is severed or when motion sensor is armed and triggered
Exterior Dimensions
# 4.81" x 2.2" x 1.25"
Other
# Battery Life:
Continuous use (lock connected, alarm "off")
Alkaline battery = 5 months
# Retractable Stainless Steel Cable:.09in (2.4 mm) diameter; 3 feet (0.9 meter) length
Technical
# Motion Sensor:high and low sensitivity modes; triggered when device is moved; if motion continues for 4 seconds, alarm will sound for 40 seconds, device then resets to armed status
# Combination Lock: re-settable to one of 10,000 unique combinations
# Electronic Alarm: loud, 95db alarm siren activated when lock is engaged; alarm sounds when cable is severed and when motion sensor is armed and triggered; alarm is deactivated when combination lock is released
Exterior Dimensions
Other
# Battery Life:
Technical
