Taum Sauk Mountain State Park
The Warrior
🇺🇸 INSANE VIKING 🇺🇸
Moderator
As most of you know, the wife and I's 5th anniversary was this past Saturday, and we rented a cabin near Lesterville, Missouri, as there are many parks in the area. Friday, we went to the highest spot in Missouri, Taum Sauk Mountain. At 1,772 feet, it isn't the Rockies, but it is beautiful there none the less. Had a great time, and it was a good learning experience for me. Will post thoughts after the photos:
Mina Sauk Falls, the destination. Also the highest falls in Missouri, at 132 feet. Notice the sign says to allow yourself 3 hours. It took us 4, but we stopped to rest periodically, stayed at the falls for some time, ate, etc, so not too bad:
The first time to use the MAP 3500. More on that later. Notice that the "trail" is concrete....
That quickly turned into this. Mud, ice, rocks, all covered in leaves. Had to be very careful:
Sometimes like this:
Smoke break. The MAP 3500, and the 14:
14 in the ice:
Ice on many parts of the trail:
My goofy butt overlooking the hills. By the way, I fit in with all the locals the way I dressed, haha:
Part of the rocky trail:
Stopped for some fuel:
Some views:
The trail on the ledge. Really had to watch your step around here:
The falls. Hard to see from the top:
So, we walked down this. Hard to see the grade, but it was a bitch:
Damn, I gotta walk back up this. Camera doesn't do depth/height justice. The leaves covered so much, every step had to count:
These are cascading falls, so kind of hard to make out:
14:
My wife in red sitting on the rock. Gives more of an idea of scope:
More random shots:
Back on top:
The trail back up top pretty much follows the stream, so there were many opportunities for water shots:
Stopped for a bite to eat:
Another smaller waterfall:
Lots of walking up on the rocky path:
Back to the top:
We had a great time. I'll post more photos of the other places later.
Here are some thoughts, and some of the things I learned;
1. Make sure to have a good hiking boot, sized right, made specifically for hiking. I wear 6" Wolverines, and they're good boots, but not made for hiking. You need a boot with great ankle support, fitted right. The bottom of my feet were a bit swollen by the time we finished the hike. Spare no expense when it comes to your feet. It'll be worth it.
2. Make sure you are in good enough shape to do the given task. I sometimes forget I'm nearly 50, and don't get much exercise. At 275 lbs, with a 40 lb pack, it wasn't easy. Harder than I thought it would be, especially climbing down steep, rocky angles, and back up again. My hip joints were giving the me the most problems. It did get better after hiking the next few days though.
3. Make sure to know your pack. This was the first time I used my MAP 3500 pack. I really liked it, and think it worked out well. I didn't need the 40lbs I had in it, but I like testing stuff out, so I went with it. Something I didn't take into consideration, was the balance, especially when it came to climbing up and down steep angles. Going down, having to watch every damn step, with all the rocks/boulders in the path, sometimes stepping over, sometimes on the rocks, it was easy for the packs weight to want to make you go forward. I had to counter this action, by maintaining balance. Same thing going up. I would sometimes have to jump to a certain spot, to maintain a foothold, and if I didn't land right, the pack naturally wanted to pull me backwards. This was a valuable lesson for me. Believe me, carrying 315lbs up a rocky, steep incline, was no easy task. I won't lie, I was tired and winded. Also, I used the hip belt, as I wanted to try it out. I liked it. Sometimes, I would get a bit of shoulder fatigue. One of the ways I countered this, was to loosen the shoulder straps, carrying most of the weight on my hips, walking uphill, and tightening the straps back up walking downhill. Maybe this makes more sense to experienced backpackers. This worked well for me.
4. Make sure to know where the sun is. I'm talking about how much daylight is left. I knew by the sign, to allow 3 hours. It took us 4. We started at 12:30, returning at 4:30. Not much time left daylight wise. Even though I was fully prepared, with water, fire, shelter, etc, and could have made a night of it, it would have been no fun walking those rocky, icy trails with a flashlight. Took us long enough with the light.
I'll post more thoughts if I think of any more.
congratz on the anniversary and thx for the pics looks likea beautiful place too hike!
Looks like a beautiful place and a great time! excellent pictures as always. Thanks for sharing
Did you get a chance to try out that pocket predator? I went thru a couple hundred rounds of ammo over the weekend shooting. im really enjoying the scout, its accurate as heck but im going to add some better performance bands for more power. I guess i should thank you, so thanks, since it was your pictures that made me want a good slingshot and now im having a blast with it.
Cool thread Dubz.
Some of those shots are amazing.
Happy Anniversary!
Thanks guys, appreciated. WW, I took, and shot my WBG a few times. I couldn't hit the broad side of a barn with that thing, haha. It kept wanting to shoot to the left, for whatever reason. Perhaps I'm doing something wrong, who knows.
Thanks for the pictures. Beautiful country.
A steel shank and decent rubber rand around the edge of your boots are important to keep feet from getting beat up on rocky trails -- especially with heavy loads or long trips.
Also consider a walking stick or two. They are a help in taking load off the knees on down-slopes and turn a shaky biped into a more stable triped (or quadruped).
Thanks. I do have a walking stick, and forgot to take it. I entertained the thought of chopping down a sapling with my 2, but didn't.
Yea when i first got this thing i wasnt able to hit my target very well shooting with the forks pointing up, but holding it sideways like i seen on alot of videos i was able to get it tuned in pretty quickly. now then again im only shooting at cans from 25 feet away so im not sure how far most people shoot the things but at this distance its not that hard to hit 5/5 shots and im not happy with 3/5, my wifes 2nd shot she nailed a can and it was her first time ever holding a slingshot. now i dont have any real experience with these things and im using 1/4" steel ammo but when i grab the beeman marksman im down to hitting maybe 1 or 2 out of 5 with that thing so i have to give the credit to the scout over skill really.
Congrats on the anniversary, here's to many many more. Looks like a great place for a weekend, nice views. Glad y'all had fun, good thing you didn't come home to beaten down and sore!
Great pics and great advice Dubz. Glad you had a good time. Did you see any signs of when the dam broke?
I am sore, haha. Woke up sick this morning as well. Wife woke up, and didn't feel well all day yesterday. She went to bed as soon as we got home.
Thanks. Sure did. We hiked the Scour Trail, the valley where the water rushed through. I have some photos of that hike as well. Will get some posted up later.
I live near Taum Sauk Mountain. Glad you had fun. I hope you have checked out Johnson Shut Ins & Elephant Rocks also in the area. The area between TS and JSI is my favorite place to backpack, along TS creek. The whole area is ate up with feral hogs and the problem gets worse every year. In fact, I can't hike hardly any trail in MO or AR and not see the feral hog signs. I've seen signs of them even at the overlook up at TS in the grassy area. I am in my mid 40s and overweight also, currently counting calories.
The dam breaking had little effect on the area right around Taum Sauk. More so over at Johnson Shut-Ins (I did an edit....I see you went over there also!)
For those that have no idea what the dam break was:
https://en.wikipedia.org/wiki/Taum_Sauk_Hydroelectric_Power_Station
Jon
I live near from Taum Sauk Mountain. Glad you had fun. I hope you have checked out Johnson Shut Ins & Elephant Rocks also in the area. The area between TS and JSI is my favorite place to backpack, along TS creek. The whole area is ate up with feral hogs and the problem gets worse every year. In fact, I can't hike hardly any trail in MO or AR and not see the feral hog signs. I've seen signs of them even at the overlook up at TS in the grassy area. I am in my mid 40s and overweight also, currently counting calories.
Jon
You're lucky to live in such a beautiful area. Yes, I have photos I'll post of all the areas mentioned. We didn't spend much time at Johnson's Shut-Ins. We hiked the Scour Trail first Saturday, and I was still pooped from the Taum Sauk hike the day before. We just did the short paved walk at Johnson. We want to go back and explore more of the area.
Look like fun, Dubz! great pix as usual. Congrats on the anniversary.
Beautiful pix Dubz and glad the MAP is working out for you. Congrats to you and the wife on 5 years!
Thanks brother, appreciate it. Thanks for the recommendation as well. Really like it, but if I were to go on a major hike, I would get a "professional" pack, like a Gregory, Osprey, etc.
Looks like a great place to hike and explore! Thanks for sharing the pics. The pics of the icy waterfalls are very nice.
Hiking with a heavy pack really is a big change from just hiking with a camelback or day pack. It's hard to really test your gear until you're out using it! Looks like you took away some valuable lessons and had a great weekend.
