Ugh. So it is heavier. Unfortunately for me that's a good thing....
What's the difference between an umnumzaan and large? Also which blade profiles are best? The standard? The tanto? The insigno? Are there any I'm forgetting?
Hmmm I like the looks of the umnum more but you make intriguing points. Still wanna hear input on the different blade shapes available before I go spending 400 on a folder...
If you find yourself wavering between the two, I'd say go for the Sebenza. You can always get an Umnumzaan later if the Sebenza doesn't satisfy you--but, again, the Sebenza is a better slicer.
How is this possible when they have the same blade grind? Optical illusion maybe?![]()
Both are hollow ground, but the Umnumzaan's blade is thicker than the Sebenza's. Exactly 3mm on the Sebenza, and ~3.52mm on the Umnumzaan. That is about 15% thicker, while keeping the same blade-grind.
Kind of like comparing the FFG Endura to the FFG Paramilitary 2. If the Umnumzaan's blade was 15% taller than the Sebenza's then it would even it out slicing ability a bit more, but with the same grinds, the thinner knife (assuming all else is the same) will slice better since it is displacing less material when cutting.
(Edit) It wouldn't be 15% taller. The hollow grinds on both are ~20mm tall. To retain the same ratios for the angle of the bladegrinds, the Umnumzaan's hollow grind would need to be ~3.47mm taller.
does anyone know if the tanto is hollow ground as well? or is it ground differently to accommodate the blade style
