- May 23, 2017
This may actually be a beginner question that hasn't came up here before.
I'm great at learning things, but admittedly not the best teacher.
My dad is getting close to retirement, and is wanting to try making some knives in addition to the woodworking and machining he already does. He's extremely experienced in the shop, with pretty well everything possible except bevel grinding. And that's where my question comes in. I've taken it on myself to teach him how to freehand flat and hollow grind. We started last night, and he's doing surprisingly well so far for a first attempt at grinding.
I thought I could explain what I've been doing and my thought process behind it, and see if anyone who has actually taught someone how to grind before would have any suggestions on making it easier.
Firstly I've been showing him how to grind the way I do, simply because I make a mess of it whenever I try something different. Its been 100% freehand, no jig or work rest, and I opted to start with hollow grinding.
My logic for starting with hollow grinding is that I'm a lot better at it than at flat grinding, I personally find it easier, and I always hollow grind a blade before flattening on the Platten anyways.
Just using mild steel practice pieces to avoid wasting 154cm, and 60 grit belts instead of my usual 36 just to slow the process down some. My grinder isn't that fast, but it is fixed speed so dialing it way down isn't an option.
Ended up trying a few different things. Firstly I started with the 12" wheel as it's what I usually grind with. That seemed rather hard for him to feel the hollow, so I switched to my 8" wheel after the first attempt. I've had him grind the left-handed side first on each one in an effort to take care of the most challenging part first.
The main issue has been following the track of the grind consistently. I tried a 120 grit belt which didn't help much, and just practicing finding an getting a feel for being in the hollow without really applying any pressure. That did seem to help some.
I'm just wondering if anyone has some suggestions on helping him develop the feel of following the hollow? Switch to the 5" wheel? Put a dull 400 grit on and get him to practicing an existing hollow I roughed in? Or just keep going as I have and cut a big pile of practice pieces?
