- Jul 11, 2016
Hi,
is this the original or LB TG i got? Cant figure it out yet.
Yea, i found those threads before, was still unsure about the grind at all because its not hollow like the LB and not beveled like the original.Use the search function my friend
110% sure it's a TGLB
Don't feed him guys, he's not trying to have a conversation.
He's trolling, which is against forum rules if I remember,
If he wanted to have a conversation, he'd stick around for the replies, but he doesn't, he runs away only to return in a week to take another sucker punch and run
OP:
It's a TGLB if you ask me, great score!
I have 2 factory TGLB's made over 2 years apart, I have one that looks like the cross section posted by Jerry Busse (the older one) and one that looks like the OP's cross section. There is enough of a difference that neither one will fit into all three sheaths that I have made for TGLB's.
Funny, the "real" Team Gemini Light Brigade bear absolutely no resemblance to the thinness of the "sample" cross-section seen here in this cross-section cutaway comparison:
These other pictures show just how thick the edge grind is, even on a confirmed, supposedly "hollow ground", LB:
In the cross-section cutaway comparison the edge looks like it is well under 1 mm in thickness, while on the actual knife, even directly looking at the heel, it is obvious it is way over 1 mm, so the cutaway comparison bears no resemblance to what the hollow ground knives are really like...: In fact, the cutaway convex grind seems to be closer to the actual LB hollow grind than the cutaway hollow grind(!)... No wonder it is confusing: It looks as if the "real" LB is as thick as the original ever was... The hollow grind is also far, far less pronounced than what the cutaway cross-section example suggests...
Frankly, it is hard to see how the real LB could be any thicker and still cut anything, while the cutaway LB looks like a plausible slicer with an obvious hollow grind... Something weird going on with the cutaway methinks... Or the actual knife... "I think a victim of the TGLB a coroner would call a victim of "blunt trauma" injuries...
Gaston
