- Apr 26, 2010
I have had both. I don't have any LB's now, and only kept an original for TWD factor.
Hello Gaston444
I've been catching up on some of your posts.
Your style of hit & run posting is considered to be trolling on this forum.
If you want to discuss knives here, then stick around for replies to your posts. If you continue to drop posts like the one quoted and then "run", I will show you how blunt I can be in response to these posts...
This is your 1st warning. Play nice.
Firestrike, May I ask which one was from the earlier production run?
IMO, his trolling posts all over the forum deserve a real infraction (not just a warning), yet nobody ever seems to give him one.Someone needs to step up, or this BS will continue. Troll is as troll does.
BTW, that's why he's on my ignore list.
The original feels really similar to the NMSFNO in heft, girth, and just size in general.
The top one is the older TGLB that is thinner, the middle is a BG, and the bottom is one of the last TGLB's ordered from the shop and this one has less of a NM treatment and is noticeably thicker through the cross section.
Sent from my SCH-S968C using Tapatalk
Assuming you ain't doing the troll thing.. the tglb is what you have an is indeed hollow grind but just a smidgen..I think Jerry called it 1% off flat..so it's ever so slight. The TGLB is the culmination of a lot of seriously awesome construction.. starting with a design that is just perfection (yes over the original imo), built with legendary infi steel, that knife is has perfect specs for its intended purpose..its light, fast in the hand..an with the awesome ibeam style tang, lots more machining was required on that blade than any other simular blade.. its just a super well thought out design by Jerry Busse.. truly something one should be proud to own...
No you're pretty spot onThe tglb was just coming out when I first heard about Busse and checked out their website. One of the things I ran into poking around on there was a piece about the light brigade treatment. I think I remember it being mentioned that the hollow grind was done with the belt running on a very large wheel, 42" comes to mind, but I could be wrong. That radius would make a grind much closer to flat (but not) than most people think of when it comes to hollow grinds.
I could also be misremembering and very wrong.
L-R older TGLB 2012 era, TGLB ordered 2015 2 hours before Jerry announced the TGLB as SOLD OUT, BGTG, TG-M![]()
Same order as 1st picture.
My favorite of these is the Orange/Black g10 on Jungle Green, best cutting geometry out of the bunch.
