I rely on breaker to the job. Ideally, you want to first power up the _spiral_ + SSR duo,
_then_ the controller. This way you spare whatever switch you got from having to
turn on 15-20A @ 240V - which is no ez task and properly rated switch will set you back
a few bux.
Breaks down like this: the SSR is by default OFF. So when you first attach the power to SSR/spiral, no current is flowing, the spiral is off and the whatever switch u use won't have to establish 20A of current right off the bat (20A @ 240V will spark like crazy and erode your switch in few throws).
Now, when u _then_ power up the PID, it inits itself, senses it needs to go up in temp and it will then tell the SSR to turn on. Since SSR is a semiconductor switch, there's never any sparks etc, it will last forever. Not only this, now that the watever electromechanical switch you use (breaker or whatever) is already ON, there will be no arcing there either.
Remember that you can run a totally separate 110V circuit to power up the PID - don't have to be same one as what goes to the SSR/Spiral.
If you want to do it the other way, then do it like this: expose some wire on the 10-11 gage wire you got going to the spiral/SSR and use some fairly thin wire to "tap" in - just wind a few turns and then use electrical tape to isolate the "taps" , and then run these thinner wires to the power-in terminals of the PID.
Doing it the other way will be tricky, as you will need to make sure you run 10-11 gage wires _all_ the way to the spiral and SSR - which will be tricky to do if you want to run this thick of a wire to the PID terminal block and _then_ out of it.
Remember that both legs of 240V are HOT - there's no neutral. So you will HAVE to run the 3rd wire, GROUND, to the oven to ground the exterior of it. Not only this, to properly break 240V, you have to do it to both legs - unlike the 110V where you only do it to the hot leg, as the other one is neutral (which is connected to the ground @ the breaker box) and thusly is safe to always be connected to whatever appliance.
