Tempering question! 2 or 3 tempers
rodriguez7
Gila wilderness knife works
Just curious what everyone is doing with high alloy steels. I’ve been using 4v a lot, and I’ve been triple tempering at 400 for 2 hours a piece. Is this overkill? Or adequate? Thanks.
With high alloy steels austenitized at the upper limit ( 2050F for 4V) , cryo and three tempers at 1000F will get good results. Two tempers may work fine, but the third will make sure.
4V may not need cryo either , but it won't hurt.
I haven’t tried the high temp temper yet. I need to experiment a little I think! I’ve tried austenizing at 2050, and 1950. Both with 400 degree tempers and cryo. I’m liking the way 1950 is testing, seems like it takes a more crisp edge, and bites into Manila rope better. No clue why. Both at 62 rc.
Depending on the desired hardness and use , the high temp tempering can give more toughness. You can hit Rc 59-60 with the high temp.
When I get my oven wired right, I’ll give it a shot. I’ve been running it off my welder/gen set . I need to rewire my shop for 220. Thanks Stacy!
