Tempering question, great HT explanation by STacy on Pg 2.
I don't think you screwed up too badly by following the manufacturer's instructions. I would lean towards a snap temper if any before cryo myself, but opinions seem to vary on this a bit so choose your theory/method and see what turns up. People are doing it both ways with apparently good results. Another's experience does not constitute proof anyway, so really the only way to find out if one method is better than the other is to do your own testing.
Interestingly, the freezing temp. that Crucible spec's on the data sheet for this steel is -112F.
You blade will be fine. You get the most out of cryo by using it as a continuation of the whole quench cooling process. There is some concern about putting too much stress on complex parts by delaying the first temper. Knives are not complex parts so we go for max effect by quench - cryo - temper - temper.
I think you'd risk more harm by starting over, than by just finishing your second temper now. I suspect it would take lab instruments to tell the difference.
Rob!
OK, super confused now. You seem to all be saying to cryo between quench and tempering. Crucible's datasheet states to freeze between the two tempers. How badly did I screw it up by doing cryo between the tempers and not between the quench and temper? Should I finish the second temper or anneal and reharden?
Double temper at 400-750. Hold 2 hours minimum each time. A freezing treatment may be used between the first and second tempers. Freezing treatments help to maintain hardenability and must always be followed by at least one temper.
This is one of those times where the manufacturer's recommendation isn't necessarily your best option. Cryo between tempers isn't going to do much. It will convert the RA that is on the edge, and in doing so prevent dimensional changes over time that are harmful to things like dies, molds and certain kinds of machine parts. It won't hurt anything, but to get the most from the steel you need to include cryo as a part of the quench. This is more important if you're using the low tempering temperatures where RA would not decompose well otherwise.
The manufacturers generally suggest ht that minimize risk of cracking, warping and dimensional changes. The simple cross section of a blade allows you to pursue a heat treat that would be too risky in many other applications. And parts such as extruder screws don't suffer much from a little RA like a knife edge. but being a little bent would be a real problem
By the way. It has been my observation that the biggest benefit of cryo is found in thin edges that are forced to failure in a non-wear mechanism such as rolling or chipping. I suspect this is probably due to areas of RA that represent a significant portion of a thin area's cross section, allowing failure.
I believe the benefit of cryo is not as great on thick edges, and thin edges that are not subject to gross failure from roll or chipping. So, depending on the kind of knife you're making, getting the cryo out of order may not make a big difference.
For example, two identical skinning knives in D2 may have very similar edge holding against hide (abrasive), but the one that received cryo as a part of the quench can then go on to tolerate bone contact that damages the edge of the knife that did not. But it might not make a lot of difference in two thick choppers.
This morning I typed a long explanation in response. I went to church and as I was leaving, decided to save it...just in case. While at church, the entire area lost power for about 20 minutes. Good call. Here it is:
Zaph, and others:
It seems clear that many people don't understand what is happening in the steel when it is hardened and tempered. I will try and give a short ( OK, not so short) explanation, but one of the problems ( like yours) from folks who learn on the internet is that reading three sentences and spending three hours trying to learn a skill is not the same as reading three books and spending three years developing the skill. Even that does not compare to reading twenty books, attending twenty seminars, and spending twenty years practicing the skill. I often get a chuckle from the "experts" who are on their third blade.
OK, enough ranting:
Steel is a combination of iron...usually about 99%, and carbon...usually about .6-1.0%.
To that they add small amounts of alloy ingredients. Some are to make it easier to make the steel, such as silicon,phosphorous, sulfur. Others are there to enhance the properties desired in the steel -Manganese, Chromium, Vanadium, Tungsten,and some others.
The alloy ingredients form various structures that are often in the form of carbides, which can make the steel harder and tougher. This comes at a price, though, over a simple steel alloy (with just iron, carbon, and a tad of manganese). Once you start adding things like chromium and vanadium, you need more heat and longer times for these to go into solution.
When the alloy becomes overstuffed with these ingredients, as in martensitic stainless steels, the iron content is reduced to as low as 70% and things like chromium, vanadium, and tungsten go up to as much as 20%. Carbon often reaches nearly the proportions of cast iron ( 2-3%). The excess carbon is needed because of the amount of carbides formed.
What does all this mean to knife makers??????
We want our blades to have a combination of two things - Hardness and Toughness.
This comes from creating a structure in the steel called Martensite. We can then manipulate the martensite into a desired blend of hardness and toughness.
So lets get out steel hot:
When we heat the steel up to a point where the atoms start to rearrange, the first major change comes around 1350F. That point is the Critical point - Ac1 or As,which means it is the beginning of the point where the steel converts to Austenite. Austenite forms at slightly different points depending on the alloy ingredients.The word "critical" means that there is a change in the physical properties (solid,liquid,gas, structure,etc.) at that point.
Next we reach the Curie point at exactly 1414F for steel. This point is the same for all steels. Its abbreviation is Tc. This is not a physical change, but deals with ferro-magnetics. At this point the steel becomes non-magnetic. Of all the "tricks of the trade" that smiths will tell you, this is the only one that is entirely accurate and repeatable. When the blade stops sticking to a magnet...it is at 1414F.
Then we reach the point where the alloy ingredients are able to go into solution. This is the target point. This point is often called Ac3 or Af. NOTE - Charts with the "s" and "f" used are easier to read, I consider that the letters mean "start' and "finish". For this reason, I will use those terms. The target is the place where all that we want to happen will, and things we don't want won't. Grain growth is the enemy when the steel gets too much above the target point.
Engineers have spent many years doing tests on steel to determine what it does and when it does it. Each steel type has its own set of data. This data is put into charts by engineers, because they do that sort of stuff for fun.
A look at one of these funny charts with funny names like TTT or ITC will show a bunch of curved lines. The curve sort of looks like a nose, and the left-most spot is called "The Nose". That "Nose" is usually about 1000F on the chart. This is the point where if your steel goes any amount right of the nose in its cooling ( takes too long to cool down), it will become partly or all pearlite ( which is not what we want). To determine what you want the chart to tell you, look at the base of the chart and the vertical side of the chart. Along the base you will see the time experssed in seconds, and then in minutes. On the vertical side you see the temperature scale.. Thus teh chart shows how soon things happen at any specific temperature . The X/Y coordinates of any sopt on the curved nose line will tell you how much time you have to get down to that temperature durring quench.
All those funny letters and names assigned to the places along the temperature chart tell you where the steel changes from one structure to another. A= austenite; M= martensite; Ferrite is iron and carbon ( body-centric for those engineer types); Cementite is a hard and brittle structure of iron and carbon; Pearlite is a soft structure made up of layers of ferrite and cementite.
Lower case sub letters, "s and f" mean start and finish. Letters "c and r" mean climbing and returning...or simply heating up and cooling down. Note that things don't always happen at the same point rising and falling.
What we are concerned with is taking a piece of steel that we have shaped into a blade and changing it from one structure to another in a controlled process we call "Heat Treatment".
We do this by first heating the steel up in an environment that won't ruin the blade. This is part the atmosphere of the forge, and part how we protect the blade form elements we don't want to add to our steel....mainly oxygen. That is for another discussion, though, and for this talk we will assume your forge/oven atmosphere is right and you did the proper things to protect the blade form evil oxygen.
Back to the funny chart. The steel starts off a mix of God-knows-what structures after we have been working on it. In the final Heat Treatment we heat it up and as it passes As/Ac1 it starts to change into austenite. Then it passes the Curie point, and our trusty magnet ceases to attract the blade. On we go as we heat up the blade until we reach the Af/Ac1 spot. This is where we want to stop heating the blade and hold it at that point ( as close to evenly as possible) during what is called the "soak". While the blade is "soaking" the alloy ingredients have time to slowly recombine into various structures, go into solution, and the evenly distribute themselves. This takes from 5 to 10 minutes for simple steels, and up to an hour for complex stainless steels. As a general rule of thumb, a 10 minute soak is used for carbon steel alloys, and 30-45 minutes used for stainless steels.
The temperature of this varies depending on the alloy ingredients. Simple carbon alloys are usually about 1400F to 1500F, and stainless steels are around 1850F to 2050F.
Once we have allowed the ingredients to go into their solutions and such, we now need to cool the blade down and make Martensite out of it. This is the "Quench" stage. By rapidly dropping the temperature past the "Pearlite Nose" we can super-cool the austenite and thus not make any pearlite. Notice that once past that nose, the amount of time starts to expand as the blade cools down. This is why we need different quenchants and methods for different steels. All we want to do is get past the nose quickly, after that we want to cool down at a rate that allows the steel to convert to martensite , but does not shock the steel any more than necessary. For some steels, like the simple 10XX series, this is fast,one second to pass the nose, but as we add those alloy ingredients, the amount of time to pass the nose increases. The "O" series steels have about ten seconds, stainless steels give you many minutes to pass the nose. Thus, the proper quenchant for these steels would be -
Water or fast oil for 10XX steels
Slower oil for O series and alloy steels like 5160
Air for D-2 and stainless steels.
Once past the nose, we can slow down the cooling rate. The steel needs time to prepare for the sudden change that will occur at the point where it changes to martensite. At this point we still have austenite ( hopefully) and the steel is rubbery soft and in no danger of cracking or breaking. As we reach the Ms point, around 450-500F, the steel rapidly converts into martensite. This is where the cracks come from. The change in structure can tear the blade in half. Thus we need to cool the blade across this area as slowly and evenly as possible. The choice of quenchant can make or break ( literally) a blade here. At about 200F the austenite has mainly converted to martensite. Any left over austenite is called RA, or "retained austenite". This is a very small amount in simple steels, and is dealt with in the tempering stages. However, with the complex stainless steel alloys, this RA is a big problem unless converted as fully as possible to martensite. The much larger percentage of RA at room temperature is due to the fact that ,while the simple steels finished their conversion to martensite (Mf) at about 200F, the stainless steels need to drop to about minus 200F, yes 200F below zero, to complete the transformation. This is done by adding a step called "cryo". The steel can be very unstable with part of it being very brittle martensite and part very rubbery austenite, so it is wise to give it a short stabilizing step called a "Snap Temper". This is a short temper cycle of about one hour at a low temperature of about 200F. This will stabilize the martensite somewhat and can avoid cracks forming in the cryo stage. After this "snap temper" the blade is cooled to room temperature and them placed in a chamber that will cool it to the sub-zero point where the Mf will finally be reached. This is typically done in liquid nitrogen, which is a bit below -300F, or in a solution of acetone/alcohol/kerosene and dry ice, which will cool the blade to about -100F. This is low enough to get most of the austenite converted, but the LN is certainly better. Economics and frequency of use usually decide which type of cyro one uses.
After the austenite is converted, it is a very strained and brittle structure. This is called Un-tempered martensite. This is corrected by tempering the steel at points between 350F and 1050F. The tempering target point is determined by a tempering chart which those engineers have also made up for you. The chart is much easier to read. It shows the estimated hardness at any given temperatrure on the curve. The first temper cycle ( after the snap temper) is to convert the martensite to tempered martensite, which is tougher, as well as convert any remaining stray bits of austenite into martensite. This newly converted martensite will, however, be un-tempered, so you need to do a second temper after cooling to room temperature. A second cryo treatment between the tempers will accomplish very little, and this is not usually done. To make it clear....cryo is done as a continuation of the cooling process during quench. After that cooling has been stopped and tempered, any cryo will be much less effective.
To state it in a flow chart for stainless steels:
Heat to austenitization > Soak > Quench > Snap temper > Cryo > First temper > Cool to room temp > Second temper
Wow Stacy, that is quite a thesis on HT. Even a know-it-all like me learned something I didn't know in there. You should save that somewhere as a reference.
Stacy, thank you. That is one of the best explanations that I have read yet of the HT process. The interesting part is that I hadn't heard of a snap temper until your post the other day where you told us about the cooler you bought for $1.
If I understand correctly, I didn't reach Mf until after cryo, which was after the first temper. Thus, the RA after the cryo was converted to martensite during my second temper, and is still untempered martensite at this point. Therefore, I need a third temper to convert the remaining martensite created during the second temper into tempered martensite.
The unanswered question is how does a temper instead of a snap temper change the outcome.
Mete +1.
AFAIR the RA is easily convertable in 20-30 minutes after the quench. It is less succeptive to the cryo later.
Instead of snap temper you can use "incomplete quench" or "interrupted quench" or the salt bath. So the piece will have something like snap temper.
As Dmitry said, the retained austenite stabilizes after a while. If you temper the steel, you aid this stabilization. The cryo after a full temper will convert some of the RA, but the main part of it will remain. A second and third temper will help convert a bit more, and ,as you discerned, temper any newly converted martensite.
Wow I wasn't even following this thread, but I glad I read that. Great information, put into layman's terms. While I know that HT is a science and takes time to learn how to do it properly that explanation will shorten the learning curve for a lot of us, thank you:thumbup:
so while a bit more risk (depending on steel)
my choice to LN2 cryo before any tempers is a good thing (again on some steels)
Stacy, could you possible explain the function of the snap temper a bit more. I understand it is to stabilize the metal a bit between the brittle martensite and rubbery austenite, but how exactly(well, not exactly) does it help. I feel as if I understand most of the process generalities as you have explained them, except for this step(snap temper). I don't understand how increasing the temperature by only 125° would stabilize the metal. Plus, I'm sure once you explain it I will say "Duh, of course!" and it will all make sense.
A second question, is Mf of stainless ever reached without going to -200°? Is there a point in time when Mf is reached at room temp?
Let's be careful about the use of the word 'stabilize' !! Here use it to mean -' treating austenite so that it resists transformation to martensite'.
Tempering at 300 F [snap temper] will reduce quenching stresses so as to prevent cracking. By 350 F retained austenite will start to be stabilized and resist transformation. You will never get rid of all the RA. RA depends on chemical composition, hardening temperature primarily.
The Ms and Mf are dependant on chemical composition. So it doesn't change with time .
Why would this blade, 24 hours after the last temper suddenly be warped? After the last temper, it was perfectly flat. I couldn't see light under it on a flat surface. Now, I can slide four dollar bills under the bow in the middle.
