Once the knife has been quenched it is time for tempering correct? Well, with 1075 steel (the steel i am currently using), how does one know the temperature at which to temper it? and for how long does it need to be tempered??
I would temper it @ 350 and then test the blade. If the edge doesn't chip out then you're fine. If it chips out, re-temper @ 400 and re-test. Keep moving the tempering temp. up until the blade performs the way you want. Re-tempering does no harm and you can always raise the temp. to make it softer but if you go tto far you will have to re-harden. Good luck and let us know how it turns out.
