Congratulations for finishing your first knife.
It suffers from BHS - blocky handle syndrome. On the next one ( or on this one) round the handle more at the corners so the cross section is more oval.
Also, those little tits of wood going down at the ricasso may snap off in use. Best to avoid sudden downturns against the grain.
Thank you for the feedback! I created another thread becuase I didnt' want to hijack this one. Please take a look and let me know if it needs more rounding. I tried to round out the tit a little bit, but I'm not sure what I can do about it at this point.
https://bladeforums.com/threads/wood-handle-curing-blocky-handle-syndrome.1639311/
This is the knife I am working on, my latest temper which scares me..
Good looking blade!
The coloring doesn't look that different than the one I posted a few posts up. What I did after tempering was sharpen the knife to see how it behaved. Then whittled and batoned to see if the edge would chip or roll.
Based on the sharpening, you should be able to tell if the steel is too soft if you're able to sharpen the knife faster than normal. Then with the whittling and batoning, you can see if it's chipping, which would indicate that it may be too hard.
No reason to go through the entire process of sanding, finishing, putting on scales, etc. only to find out that the temper isn't to your satisfaction.
Once the epoxy is on the handle, it won't be easy to change the temper without affecting the epoxy bond.
