Took a reciprocating saw and cut a 8"x8" square hole centered on a stud. The sheetrock was not screwed to the stud in this square and was only glued. Stuck tenacious into cut about a 1/2" and barely pried against the sheetrock just enough so I could get my fingers behind it to pull it off. SNAP!!!!!!!
. Had to take my para2 to work today and I like it to much to use for work. So I need a new knife in the same price range as the tenacious. What would you guys recommend that has a stronger blade but not so expensive to use for work. Thanks.
