Tenacious Low Rider Pocket Clip for $7 USAKnifeMaker.com
How did it work for you? Any issues?
I received it and test fitted. I couldn't get both screws to line up with the Tenacious holes. I tried to file/elongate the holes with no luck. It's been sitting on my bench for a while now, I haven't had the motivation to mess with it. I recently got married and went on a honeymoon so the clip has been the last thing on my mind.
I'll try and get it to fit right this week.
it wont fit the paramilitary because the spacing distance is .260'' for the PM and the one on usaknifemakers is .340''.
Do you know if the hole pattern is the same on the PM2 as it is on the Tenacious? Or, do you have a PM2 you could try this clip out on?
Thanks
Well, I finally found time to mess with this clip. I ended up having to use needle files and elongate the holes 'outward'. I also smoothed the edges as they were a little sharp for my taste. Here it is installed......
What was the size of the needle file that you used to widen the holes on this clip?
